Things you can do for more efficiency
Discussion in 'The Wood Pile' started by Tasmaniac, Jun 3, 2014.
  1. Tasmaniac
    Tasmaniac
    Tasmania
    Here in Tassie especially in some old pubs with older 12ft ceiling heights some use ceiling fans which spin in "winter mode" and direct the heat down. Also some guys put corregated iron panels screwed to the walls near the stove that protrude out 2 inches which act as a radiant heater of sorts. The air circulates around the piece of metal from on sides and gets very hot which adds a secondary heating effect. Sort of like a way a hydronic set-up would work.
    Im thinking about these things to try to get the most out of my wood. Is it worth the hassle and is there better ways?
  2. WVhunter
    WVhunter
    Mountains of WV
    I have a ceiling fan almost directly above my stove and it definitely helps.
  3. Tasmaniac
    Tasmaniac
    Tasmania
    Being on solar I don't want to run a fan in winter because it takes away much needed power in a time of low solar generation. Does anyone know of other ways to get more efficiency?
  4. swags
    swags Moderator
    You can get fans that sit on top of the stove and are run by heat from the stove
    Stinny likes this.
  5. Tasmaniac
    Tasmaniac
    Tasmania
    The consensus here is that they are not worth it. I posted a thread last week enquiring about them actually but they received a poor review.
    Stinny likes this.
  6. Paul bunion
    Paul bunion
    I always thought that the sheet metal held off the wall trick was a way to make a heat shield when you don't have sufficient clearance from a combustible surface. That was our intention when we did it in our camp. We put a piece of sheet metal on the wall and another piece set off the wall with a little air gap.
    concretegrazer and papadave like this.
  7. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Stone Hearth?
  8. Tasmaniac
    Tasmaniac
    Tasmania
    It would protect the walls as well no doubt but some do it anyway just for the added heating effect even with suitable clearances.
    papadave likes this.
  9. Tasmaniac
    Tasmaniac
    Tasmania
    Yeah got one myself.
  10. BrianK
    BrianK
    West central PA
    Google search "diy homemade eco fan"
  11. Stinny
    Not from me... I love em. Now, if we had power at the cabin, we'd use a muffin fan. But, a fan that doesn't even need batteries... :yes:
  12. nate
    nate Banned
    Palmer, AK
    I have ~18ft ceiling where my stove is. Running the ceiling fan doesn't do much. Even at -20* the air 2ft off the floor is within a few degrees if the air at the ceiling.
    Seal and insulate.
  13. papadave
    Gonna' echo nate's suggestion to seal and insulate.
    Best "bang for the buck".
  14. Backwoods Savage
    Except that "winter mode" usually means drawing the air up rather than pushing it down.
  15. papadave
    Maybe air moves in reverse in Tasmania.:D
    What say ye', Tasmaniac?
    Stinny likes this.
  16. Tasmaniac
    Tasmaniac
    Tasmania
    I used to tell the ladies.
    "Have you ever had a Tassie kiss?"
    "No. What's that?"
    "It's like a French one but it's down under "
  17. papadave
    Uh,...um, well.
    Yeah, I knew that.
    Stinny likes this.
  18. Stinny
  19. Oliver1655
    Oliver1655
    Central Missouri
    Pull the air up or push it down, the end result is the air is stirred & the heat is re-distributed.
  20. Backwoods Savage
    Yes, it can work but to work the best, pull the air up in winter and push it down in summer. That is usually called working with nature. Something like rowing with the flow.
    Stinny and papadave like this.
