Things I've learned this burn season
Discussion in 'Modern EPA Stoves and Fireplaces' started by Dunmyer mowing llc, Dec 10, 2024.
  1. Dunmyer mowing llc
    Dunmyer mowing llc
    Indiana
    Wanted to make this thread for any of the newer burners that have tube stoves.
    This is our 4th year heating with wood.
    Start of 2nd full season with our current stove.
    Things I've learned this season.
    Thermal mass (in our case about 1500lbs of concrete block) really makes a huge difference. Our houses has been consistently around 10f warmer this year.
    A tube stove is much much more efficient than a pre EPA stove (I've experimented with mine, in both configurations) it uses less wood and puts out more heat when tube system is working.
    The most efficient way to burn a tube stove in my opinion is
    Once fire is well established and up to temp close flue damper 100% to slow down exhaust while leaving air intakes as open as possible to reach your stovepipe/flue temps goals. ( Mine is 300f on exterior of pipe 18" above stovetop)
    In milder temps for me this is near 100% open, on bitter cold/windy days this might be all the way down to the idle setting.
    I've found that running a tube stove this way gives you maximum heat and longevity of fire. It keeps the secondaries in the box for longer therefore burning more smoke and slowing down the actual burn of the wood.
    It's taken me many many mods on my stove to get this thing figured out/ consistently performing well.
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  3. billb3
    when I was not single if I had my boots on in the house I would be in the prison with the wood.
    Allman27, Eckie, MAF143 and 2 others like this.
  4. Dunmyer mowing llc
    Dunmyer mowing llc
    Indiana
    The Mrs has learned it's not worth the fight.
    If I'm making multiple trips in and out ain't no way I'm taking them off each time
    MAF143, MikeInMa, billb3 and 2 others like this.
  5. buzz-saw
    buzz-saw
    Ct.
    Bad wood.
    Eckie, MAF143, MikeInMa and 1 other person like this.
  6. buzz-saw
    buzz-saw
    Ct.
    I thought there was a firewood abuse thread , maybe that picture belongs there.
    Wrongfully convicted, jailed and sentenced to death in the stove.
    brenndatomu, Eckie, MAF143 and 2 others like this.
  7. Todd
    Todd
    NW WIS
    I’ve learned that once the temps dip below zero all bets are off. No more long 12 hour burn schedules. Keep the stove hot with smaller loads and more air to keep coaling down.
  8. chris
    chris
    SE WI
    with all that weight in one location might want brace the floor from below.
    blacktail and JoeyD like this.
  9. Dunmyer mowing llc
    Dunmyer mowing llc
    Indiana
    I did
    Put 3 floor joist jacks down there
    theburtman likes this.
  10. rusty ranger 44
    rusty ranger 44
    south central Pa
    still holding for correct moisture content
  11. Canadian border VT
    I got a different stove, stove itself weighs over 850 pounds so thermal mass was less important in my application.. glad it is working for you
    Dunmyer mowing llc likes this.
  12. BuckeyeFootball
    BuckeyeFootball
    Modern stoves are awesome. Both tube stoves I've had were larger and probably at least more than 2x as efficient as my FIL's potbelly stove. That thing is a joke I can't believe how much wood he goes through.
