Thermostat for England Stove Works 25-pdvc/55-shp10
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by rjdb, Oct 26, 2020.
  1. rjdb
    rjdb
    Plaistow NH
    Looks for a thermostat that works with this model stove. Manual says I need to connect it to the control panel and it must have millivolt sensitivity.
  2. imacman
    imacman
    Denver, NC
    Pretty much any standard millivolt stat will work. I used this Lux model with great success, although it has been replaced:
    This model is close to that and would work just fine....
    LuxPRO PSP511LC
  3. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  4. rjdb
    rjdb
    Plaistow NH
    Just ordered, thank you.
  5. slvrblkk
    slvrblkk
    Northampton, PA
    X3
    badbob, CleanFire and imacman like this.
  6. rjdb
    rjdb
    Plaistow NH
    So I got this and then connect the thermostat, and I get an e-2 code, then e-1, then it shuts off... what the bleep did I do wrong I wonder? DOes it need the back cover on? I wouldn't think so because it has venting slots.
  7. rjdb
    rjdb
    Plaistow NH
    Well looks like I'm an idiot, i walked over checked the control board and a jumper wasn't attached. Attached it and all seems good now!
    badbob, Earl764, imacman and 3 others like this.
  8. rjdb
    rjdb
    Plaistow NH
    Another idiot question... how the hell do I knw the thermostat is working? I tested the wires with a mulitmeter, they're outputting 9V, is this right? I cannot tell when the stove goes into "idle mode".
  9. Ssyko
    Ssyko
    Lorrain NY
    Set your stove to heat setting 7(or where you would have it for the cold), thermostat to 90. Let it run 15-20 min then turn tstat back down, stove shoulg go back to a small idle fire. So the stove should ramp up at the call for heat and drop to idle when it reaches set temp. Now those stoves take a few minutes to ramp up and down so keep that in mind
  10. imacman
    imacman
    Denver, NC
    I just read your post above, and remembered this post from last week.....AFAIK, the jumper is NOT supposed to be in the stat connections. It is supposed to be removed, and just the stat wires go into those connections.
    badbob, Rich250 and Ssyko like this.
  11. Pete Zahria
    Pete Zahria
    New Hampster
    I have that one too, on the Harman..
    And on the NG furnace.
    Dan
    imacman likes this.
  12. rjdb
    rjdb
    Plaistow NH
    Do you guys know what the output voltage is supposed to be on the thermostat leads?
    imacman likes this.
  13. Ssyko
    Ssyko
    Lorrain NY
    Depends on the thermostat. Some are high voltage using 120vac usuall electric base board. Some are 24v powerd some are millivolt. If your tstat has 2 AA batteries its going to be a millivolt syst. They usually have 25-35 millivolt output ( less than 1 volt )
