The Most Affordable, High Efficiency Wood Stove! This little powerhouse is perfect for heating small spaces up to 1,000 sq.ft., has an output of 27,294 BTU's/hr, an efficiency rating of 79.4%, and emissions of 1.05 gm/hr! These combined efficiency and emissions results makes the Survival Hybrid Wood Stove the ideal wood stove for smaller spaces. The Survival Hybrid Wood Stove is the smallest, most affordable, wood stove in our lineup! You won't find a better deal on a high quality, made in America, high efficiency, low emissions, wood stove, anywhere else. The Survival Stove is an offshoot of our Navajo Project, where the challenge was to design a small combination wood/coal stove that would burn both fuels as cleanly and efficiently as possible. Starts at $1407 DIMENSIONS & SPECIFICATIONS HxWxD (Max.Leg Height): 36.5"x19.5"x26" Footprint: 16.5"W x 18.5"D Firebox Size: 1.2 Cu. ft. Wood Length (Maximum): 16" Area Heated: up to 1,000 sq.ft. BTU Output: 15,332-27,294/hr (per EPA tests) EPA Efficiency: 79.4% (per EPA tests) Combustion System: Hybrid (Catalyst & Secondary Air) 2020 EPA Approved EPA Emissions: 1.05 grams/hr (per EPA tests) 2100 Degree Stainless Foil Catalyst: Standard Easy Catalyst Access: Just Lift the Top Lid! Cooktop: Standard Flue Exit: Top only Flue Size: 6" Draft Control: Manual Burn Time: 6-8 hrs Window Size (viewable): 7"H x 6"W Loading Door: Front Only Loading Door (WxH): 8"W x 9"H Weight: 310 lbs. Mobile Home Approved Ash Pan: Standard Bottom Heat Shield: Standard Rear Heat Shield: Standard Side Heat Shields: Standard Stove Rear Clearance: 9" Stove Side Clearance: 9" Stove Corner Clearance: 9" Minimum Hearth Size: 30"W x 48"D UL Listed to 1482 Thoughts on this one?? Looking for something smaller to heat an area of about 700 sq ft...
OP- a word of caution, I am loooong winded about this stove. Have a read and if there’s anything in particular that you think I could help you with, by all means ask away. As my burn season is morphing into the cutting and splitting season again, I’ll be looking for reasons to rest my back I’m sure.
