The new chute
Discussion in 'The Wood Pile' started by Smokey jeff, Oct 3, 2018.
  1. Smokey jeff
    Smokey jeff
    Central nj
    Last winter I carried about 4 cords through the house down the cellar steps to the stove.Well I got tied of that real quick as you could imagine so I decided to install a chute through a old cellar window.I was inspired by bogeydaves design.Picked up some 12” pvc from a buddy in the construction business for free then grabbed a 12” cap at the local plumbing supply.Im thinking this will make my life a bit easier this winter:D
  2. Chris F
    Chris F
    Micksburg, Ontario
    Good thinking and good job Smokey jeff! Just stick a plug of fiberglass insulation in it and you're good to go.
    M2theB, Chvymn99, T.Jeff Veal and 7 others like this.
  3. papadave
    Nice job. It's a mini-me firewood chute. :thumbs:
    Chvymn99, T.Jeff Veal, Chaz and 8 others like this.
  4. Smokey jeff
    Smokey jeff
    Central nj
    Yea I was thinking about something like this to keep the cold draft down.Is this your method?
    Chvymn99, T.Jeff Veal, Chaz and 5 others like this.
  5. MikeyB
    MikeyB
    Long Island NY
    Very cool Smokey.
  6. Smokey jeff
    Smokey jeff
    Central nj
    Didn’t want to shell out big$$$ for 16” pvc so the 12” will have to do.My splits and rounds are nowhere near 12” so I should be good:dex:
    Chvymn99, T.Jeff Veal, Chaz and 7 others like this.
  7. Maina
    Maina
    Maine
    Whatever you choose for insulation, put it in a plastic bag and it will be easier to handle for every in and out.
    Chvymn99, shack, Ralphie Boy and 12 others like this.
  8. Smokey jeff
    Smokey jeff
    Central nj
    Great idea!!
  9. Warner
    Warner
    That is sweet! All my basement windows are in not good spots to fill in like you did. I’m tempted to drill a hole in the foundation.
  10. blacksmithden
    blacksmithden
    Alberta Canada
    Nice setup !! Your back will thank you for doing this Smoky. I just put in my trap door next to my stove/wood rack and it turned a 45 minute job into a 10 minute job. Also, no mess going from one end of the house to the other. I wish I'd done it long before now.
  11. Chris F
    Chris F
    Micksburg, Ontario
    Similar. My wood door is six inches thick and insulated in the center. Four sliding bolts to retract and I lift it inside and put it out of the way. It's not too heavy.
    I also put a sealing gasket on the outside of it that seals tight when it's locked in place.
    bear 1998, Chvymn99, Maina and 4 others like this.
  12. Loon
    Loon
    North of the border
    Nice riggen jeff! Your back woulda been happier if it was a couple feet higher. just saying.:salute: :coldone:
  13. Loon
    Loon
    North of the border
    Double dog dare ya. :thumbs: :cheers:
  14. Smokey jeff
    Smokey jeff
    Central nj
    I thought about that but I think I’ll be ok.Its kind of deceiving to the eye in this pic.Pretty much at a level where I can grab from the cart and drop down the chute.I didn’t want it too obvious with a big pipe sticking out the wall.
    papadave, bear 1998, Chvymn99 and 3 others like this.
  15. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Sweet chute. Well done.
    Chaz, bear 1998, Chvymn99 and 3 others like this.
  16. brenndatomu
    You could get another short piece of pipe and a coupler...just pop it on there for an extension when you want to use it, back off and out of the way when you are done...
    Elvisss222, papadave, Chaz and 8 others like this.
  17. Smokey jeff
    Smokey jeff
    Central nj
    Good point.I have a extra 3’ section of pipe hanging around.I just might use it for that purpose in the future.
    Chaz, bear 1998, Chvymn99 and 5 others like this.
  18. T.Jeff Veal
  19. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Well executed!:salute: Insulation in a plastic bag :yes:
    Chaz, bear 1998, Smokey jeff and 3 others like this.
  20. shack
    shack
    Upstate NY
    That's the kind of project that is dang helpful...yet it's a project many put off. Smile while you drop the cord wood like a mortar.
    papadave, Chaz, T.Jeff Veal and 5 others like this.
