Teach me about Pine
Discussion in 'The Wood Pile' started by sirbuildalot, Dec 16, 2019.
  1. sirbuildalot
    sirbuildalot
    Mass
    I've always tossed pine aside as a junk wood. Kind of wrote it off. After reading multiple threads about it, I've decided I think I'm going to start using it as a shoulder season wood. Maybe even mix it in with hardwood stove loads a couple pieces at a time to make the good stuff last longer. Seems stupid to waste it, as I have a ton of it.
    How do you guys incorporate your Pine into your burning schedule? What types of Pine are most common to the Massachusetts area. It seems like Eastern White Pine would be the main one around here.
    Chaz, FatBoy85, Chvymn99 and 9 others like this.
  2. Canadian border VT
    sirbuildalot, I burn it and I have specifically dry pine. What you really have to realize without getting into the good and bad of it. Is the pine everybody burns out west is naturally a lot drier then what we have here. I mean think about it out west their average humidity is 30% where as ours I’m next to lake Champlain can average 65% and up.
    Like all wood it needs to be dry to burn well why easterners get in trouble with pine is it will burn wet due the sap causing creosote.
  3. Horkn
    I think you've got a good idea already. Try it, you'll like it. Adding a piece to a few leftover coals will get the fire going quickly.
  4. Backwoods Savage
    Pine is fine so long as you don't depend on it for overnight fires. For that you need some good hardwood. But any other time, pine works out well. We usually burn it in spring or fall so only put in maybe 3 pieces at a time. It throws good quick heat so work out really well for those quick fires that you don't want to last too long lest you get roasted out. That is where pine really shines. Well, it smells good too.
    Chaz, JDU, brenndatomu and 6 others like this.
  5. Midwinter
    I'm getting interested in the 3 red pines that Asplundh is cutting across the street from me. IMG_20191216_6316.jpg
    At 17.9 btu, they pack more of a punch than eastern white pine at 13.2. A few rounds may happen to roll into my driveway.
    BCB, Marvin, Lone_Gun and 14 others like this.
  6. sirbuildalot
    sirbuildalot
    Mass
    Is one year enough time to season white or red pine to burn?
    Chaz, amateur cutter, Horkn and 3 others like this.
  7. Midwinter
    I guess I'll find out. All the pine I've ever burned has been many years old and dry as a bone.
  8. timusp40
    timusp40
    Lake Orion, Michigan
    We burn it mixed in with other hardwood. I try to stay away from the heavily knotted pieces sincce they have the most pine sap. Other than that, just split stack and dry no problem.
    Chaz, MFMc., amateur cutter and 5 others like this.
  9. Woodsman
    Woodsman
    NW CT
    Nothing wrong with pine at al. I scrounge pine whenever I see it. Have tossed some dry pine into our wood stove on ocassion. Burns just fine alongside hardwood. Like you said, helps the good stuff last a little longer. Last year I burned about 85% eastern white pine and hemlock in our maple sugaring arch. It was cut one year prior to use and split only 6 months before use. Stuff was dry and it burned HOT. Could have got maybe a cups worth (that’s a big maybe) of buildup out of the stovepipe at the end of the season. Have another 3 cord of pine and hemlock ready to go for this coming maple season. Ensure it’s properly seasoned, as was mentioned, and it’ll be a good addition for you.
  10. MikeInMa
    This is located in the "resources" section, at the top of the page.
    Firewood BTU & Drying Chart
    Drying tines and other goodies in there. Sortable by clicking on column headers
  11. sirbuildalot
    sirbuildalot
    Mass
    Thanks Mike,
    According to that chart, both Eastern White, and Red Pines only take 6 months to season.
    Has anyone burned significant amounts of seasoned Pine? I could extend my hardwood seasoning by a few months by cutting a bunch of Pine this winter and burn it come October, up until it really gets cold in say January. It'd be about 9 months seasoned by then if I can get it done in January. I have quite a bit laying around. At least 3 full cords worth. That chart also re-inforced that I need more seasoning time for my hardwoods. I'll get to a 3 year plan....eventually!!! I cant seem to get past the 12-18 month plan right now!!!
  12. sirbuildalot
    sirbuildalot
    Mass
    I've been trying to think of a way to get an extra year of seasoning in without buying any wood. This may be my golden ticket.
    M2theB, Chaz, blacktail and 7 others like this.
  13. mrfancyplants
    mrfancyplants
    South Carolina
    Pine, cedar and tulip poplar definitely help out getting the first year done. Tulip poplar isn’t on the charts, but I measured some at 20% with the moisture meter (after about six warmer months). The thing for me with the low density wood is that I want to save some for getting the fire going easily in the morning. I.e. not use it all of at once. It saves time tinkering and gets going so well you can turn down the air sooner.
  14. Maina
    Maina
    Maine
    I burned over a cord of eastern white pine last winter that only had about 6 months drying since CSS and it burned great.
  15. billb3
    In the past I've had a dump in the woods just for "junk" pine. I just didn't have time for it. I processed and saved very little (not NONE), mostly split small for kindling. Something I could do on a rainy day in the garage.
    Now that I have more time, I process and burn more of it. I don't mind loading the stove twice as often and as much as you have to cut, split and stack twice as much, it's fairly easy to cut.
    One thing I have found and this could be just my stove, is mixed with oak and the air cut back to control the pine burn rate, the oak tends to smolder. SO I no longer try to mix them except to throw a charge of oak on top of what is left of a pine burn. My first load in the morning is almost always pine as it gets the stove back up to speed nice and quick. It lights fairly easily so makes two cold starts a day in shoulder season fairly effortless. So I find myself using much more of it both in shoulder season and mid-season.
    So I cut and process more and more of it and still run out/low.
    This is eastern white pine. There's very little red pine and pitch pine here so I have little experience with either to compare similarities or differences compared to EWP.
    M2theB, Chaz, amateur cutter and 4 others like this.
  16. saewoody
    saewoody
    Central CT
    Well, since nobody has told you yet:
    DON’T DO IT. YOU ARE GOING TO BURN YOUR HOUSE DOWN!!!!
  17. Horkn
    Quick seasoning wood is the best way to get ahead on a multi year stack, as well as if you don't have a lot of run to store longer seas time wood. Imagine if you only had oak, and you could only see which wood at your home for 2 years? You'd constantly be SOL because oak takes 3 or more years to dry out properly.
    With many pine and conifers being able to dry properly in 6 months, you can literally CSS it at the end of one burning season, and have it ready at the start of the next heating season.
    papadave, Chaz, Maina and 1 other person like this.
  18. Midwinter
    Lotsa pine up for grabs across the street, too bad it will get snowed on tomorrow. I'm guessing this is red pine, someone else may know better. IMG_20191216_13556.jpg It doesn't look like there's any fatwood in the butts. IMG_20191216_34572.jpg IMG_20191216_22282.jpg I'll probably take a few chunks in the morning.
    FatBoy85, Marvin, papadave and 9 others like this.
  19. Horkn
    I've burned a lot of red pine, aka Norway pine, and it definitely seasons in less than a year. Honestly, I think it can season in a less than 6 months given dry enough conditions, which is what I am used to the cabin.
    FatBoy85, Chaz, MFMc. and 4 others like this.
  20. MikeInMa
    Uphill or downhill roll, across the street to your side?
    :cool:
    FatBoy85, Chaz, Maina and 6 others like this.
