Surface Moisture and Creosote
Discussion in 'The Wood Pile' started by firecracker_77, Dec 21, 2013.
  1. firecracker_77
    firecracker_77
    IL
    If you bring in wood that was wet from rain or snow, and you place it on a hot fire, does the steam coming off the wood result in creosote formation? It's been snow, thaw, rain here for a couple days. All wood is wet as I lack a woodshed and I can only store so much inside under cover.
    NortheastAl likes this.
  2. Backwoods Savage
    No, unless your chimney is too cool but building a fire means you are sending lots of heat up at the time so you should be okay.
  3. Lumber-Jack
    Lumber-Jack
    I would have to disagree in principle with Dennis on this one.
    Any excess water in, or on, your wood that you have to evaporate in your firebox is going to tend to lead to cooler fires and stack temperatures, and consequently more creosote formation than if the water wasn't there. Generally surface moisture, or ice, will dry off fast if you can leave the wood near the stove (not too near) for a while before burning it. Most people have a spot near their stove where they store wood they plan on burning right away, that should be enough for the water or ice to melt off before you throw it in the stove.
    Mitch Newton likes this.
  4. bogydave
    + 1
    Give it some time indoors to dry off.
    Lots of Benefits :)
    Why throw a cup or 2 of water in the stove.?
    raybonz and milleo like this.
  5. fox9988
    fox9988
    NW Arkansas 72717
    Dry wood is always better than wet, but ya gotta do what ya gotta do.
  6. blwncrewchief
    blwncrewchief
    NorthCentral, IN
    Moisture or wet? A little damp on a hot coal bed probably not a problem. Soaking wet not good.
  7. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Had a big split a couple of days ago that was heavy and soaking wet. Sat it by the stove for two days it became very light and took off immediately when thrown in the stove.
  8. fox9988
    fox9988
    NW Arkansas 72717
    What kind of wood, was it punky? Some of my oak gets a layer of punk in the sapwood.
  9. firecracker_77
    firecracker_77
    IL
    I agree that you should get it as dry as possible. Hopefully, the little rain spell we've been having is over for the winter. I'm not burning right now and my wood has been sitting indoors drying since Friday. It's supposed to turn cold tonight and stay cold so any moisture will freeze and eventually go from ice to dry slowly. Ground will freeze to which is preferable to walking through soft, wet grass.
