Supersplit bearing question
Discussion in 'Chainsaws and Power Equipment' started by Rearscreen, Aug 29, 2020.
  1. Rearscreen
    Rearscreen
    Got the Junior model Supersplit yesterday what a beast! So, the bearing 064C, the one that needs lubrication, what type of bearing is that? I ask because the manual says all bearings (except for the flywheel) are sealed. I will lubricate it as directed, but if it's a sealed bearing why lubricate? Thanks
    Horkn and Chaz like this.
  2. sirbuildalot
    sirbuildalot
    Mass
    There is no junior model. The J model doesn’t stand for junior. They are all the same size physically. Not sure why J, but it’s just the original. You shouldn’t need to lubricate the bearing itself, but you do need to lubricate the beam that the bearing rides on top of. I use a spray on gel grease like you’d use on a motorcycle roller chain. Seems to last longer and clings better than a cheaper product like WD40. The bearing is really a yoke cam follower. If it develops a flat spot it won’t return the rack well. They are not expensive or hard to replace. I think the last time I ordered them I bought 3 Japanese made ones for 20 dollars or so. The key is to give the cam follower a smooth surface to glide over. That means frequently scraping the top of the beam with a putty knife and keeping it lubed.
    Screwloose and Horkn like this.
  3. sevensandeights
    sevensandeights
    NW PA
    If it is a newer unit, the bolt that holds that bearing in place should be drilled so you can grease the bearing with grease gun using a needle tip.
    Warner and SKEETER McCLUSKEY like this.
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    It is greaseable unlike what others have posted here.
    The bolt is thru drilled and cross drilled like sevensandeights said.
    Warner likes this.
  5. sirbuildalot
    sirbuildalot
    Mass
    If the newer Super splits have a grease-able bearing its a newer "upgrade" by SS. Older units did not have a grease-able bearing, it was a common complaint on numerous forums. My mistake.
    So in addition to my other advice which still holds true, I agree that the bearing if grease-abale should be greased.
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    not sure what your idea of "new" is....my splitter is 19 years old
    Warner likes this.
  7. sirbuildalot
    sirbuildalot
    Mass
    My J model was bought new in 2011. I know they made changes in 2012 area. Things like flywheel weights, engine options, etc. Mine doesn’t have a sealed bearing or a through drilled bolt holding the cam follower to accept grease. Sevenandeights stated “newer” units have a through drilled bolt. Mine does not. If your 19 year old machine has that feature then either they used to do it and stopped and restarted or your drilled bolt was not from the factory that way.
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Wow!! Got the answers for everything dont ya?
  9. sirbuildalot
    sirbuildalot
    Mass
    I’m sorry my well thought out reply was too technical for you to reply with anything intelligent
    Deer Meadow Farm likes this.
