Super Split retract mechanism
Discussion in 'Chainsaws and Power Equipment' started by Rearscreen, Jul 24, 2020.
  1. Rearscreen
    Rearscreen
    While I await my Super Split, I sit here and watch videos of endless logs being spit. But, many users push back on the rack as it doesn't retract completely. Any insight? That's something I do not want to do.
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    The top of the beam needs to be kept clean....theres a little spring loaded follower that rides on top of the beam and it will get build-up under it.if its clean and lubed theres no problem with it retracting by itself....its actually very fast.
  3. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    i just keep a putty knife on a s hook attached to the splitter and give it a scrape when it starts building up
  4. sirbuildalot
    sirbuildalot
    Mass
    As others have noted, keep the top of the beam clean, clean, clean. Also, you can set the splitter up so the wedge is a little higher than the ram so it goes with gravity better. Last year I started using a new spray on gel grease that clings a lot better than something thin like WD40. I think its WD40 specialist gel grease or something like that.
  5. AJtree88
    AJtree88
    As others have mentioned, keep the rail clean. I also just shorten the springs a little at the back of the machine. Just grab an inch or so of the coil and slip it in between the frame to shorten the spring without actually cutting off any of the spring. Adjust accordingly.
    brenndatomu likes this.
  6. mr.finn
    mr.finn
    Mass
    A few good pointers here. I usually put a 2x10 under the front leg(gravity helps) Keep a scraper handy and lube the bearings every so often.
