Summerizing the stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by Mitch Newton, Apr 11, 2014.
  1. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Of course it's time to clean, inspect, repair, etc. after a long hard burning season. Does anyone put a drying agent in the stove or fireplace? Like "Moisture Rid" or "Cat Litter". I had some surface rust on my stove last year and some rust on the damper in my fireplace. Just wondering if some sort of moisture absorbent material should be placed in the stove and FP?
  2. Stinny
    Dry hay came to mind. Bought an old snowsled years back that should have been a rust bucket, especially the skis… but there was no rust anywhere on the skis. The sled had been stored for years in an old hay barn with hay all around it. Guy at a sled dealership said they've seen that before too.
  3. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I leave the ash in the stove all summer.
  4. Scotty Overkill
    I'm like BBar, I usually leave a bed of ash in the stove as it seems to act like a moisture absorber.
    However, this year I plan on cleaning the inside with a scotch pad or something, and wiping the whole thing down inside with canola oil or light machine oil to keep the rust at bay. At least that is what I was thinking of doing. Anyone else have any ideas?
    I'm also going to fabricate some 3/8" id stainless steel venturi lines to inject heated air up the flue when I open the doors on the NZ3000.....it likes to spill some smoke into the room upon opening, even when you are slow and careful. It'll be wired on its own on/off swith. that will activate when the right door is opened.
    jeff_t likes this.
  5. jeff_t
    jeff_t
    SE MI
    You are using compressed air? Are you going to the center of the flue? Interesting idea.
    My stove has a pretty healthy coating of creosote inside. I don't go crazy cleaning it, mostly because I'm not above building a fire at anytime in the summer.
    papadave likes this.
  6. Scotty Overkill
    Jeff, I'm going to use a squirrel cage blower to and fabricate a tapered "funnel" that will channel into the two venturi tubes. They won't be centered in the flue, they'll be against the walls and bent inward where they end (opposite each other) where they will force a vacuum up the flue. I did this with an indoor smoker we built several years ago at work and it works flawlessly.
    jeff_t likes this.
  7. My IS heats my home
    My IS heats my home
    Albany, NH
    This guy is summerizing my stove right out the door. :)
    Oslo out IS in....
  8. Scotty Overkill
    gettin' a new one, Oz?
  9. My IS heats my home
    My IS heats my home
    Albany, NH
    yeah, WS IS! Had two bad years with the Jotul. Tried solving the problems here, the other forum and with my stove shop, nothing worked.
    I'm really disappointed with it.
    BrowningBAR and Scotty Overkill like this.
  10. jeff_t
    jeff_t
    SE MI
    I see. Doesn't seem like there would be much air thru those small tubes, at low pressure, but I guess it wouldn't take much.
  11. Scotty Overkill
    Good luck, and keep us in the loop on the install!
    My IS heats my home and papadave like this.
  12. Scotty Overkill
    We'll find out soon if it works....The pipe on the smoker was a lot smaller dieter so the volume may make the blower inept. I am have to hook up a line from the compressor and a magnet valve if the fan doesn't work.
  13. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Avatar name change?
  14. Scotty Overkill
    Hmmmmm.....IdealSteel, maybe??
    Just say the word, Oz......;)
  15. savemoney
    I put containers of damp rid in after a really good cleaning. Cheap rust protection.
  16. DexterDay
    DexterDay Administrator
    Northeast Oh
    And a light coating of Pam cooking spray. Most pellet burners do this, but very few wood burners.
    I do it in all stoves. Rust will eventually eat everything. Better to protect your investment.
    Some have great luck with ash. I did not fair so well. So I use an absorbent and an oil and plug the OAK & Flue/Exhaust (air infiltration is not good. I like my A/C inside my home)
  17. My IS heats my home
    My IS heats my home
    Albany, NH
    Absolutely!
    fishingpol and Scotty Overkill like this.
  18. My IS heats my home
    My IS heats my home
    Albany, NH
    I'll be contacting you for sure Scotty . I don't want to get any bad karma by doing anything before the stove is actually here.
  19. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Dex, the Pam cooking spray sounds pretty easy, plus the damp rid. May try blocking the flue also. Thanks for the suggestions guys.:thumbs:
  20. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    At the very least, you should enjoy the bigger firebox.
