Strapping / Banding
Discussion in 'The Wood Pile' started by dgeesaman, Jul 12, 2015.
  1. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I'm looking to buy a kit for strapping my pallets of firewood. Looks like polyester is the right stuff for outdoor use and cheaper than steel banding. It needs to last outdoors through the seasoning process.
    Anyone used this? How strong should the strapping be, and should I seal it or buckle it?
    http://strapping.strapsolutions.com...hine-grade-and-hand-grade-polyester-strappi-2
    Bonus points for a system that will be handy around the farm.
    Thanks,
    David
    Drvn4wood likes this.
  2. Deacon
    Deacon
    Eastern Nebr.
    Great idea!
    Should prevent crumbling stacks.:heidi:
    Your strapping may get lose as the wood dries/ shrinks?
    I wrap my pallets in stretch wrap.
    :sherlock:
  3. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Looks like a great idea. I would go with the buckle idea to be able to tighten as the wood dries and shrinks as Deacon mentioned. Are the buckle ones reusable as well?
    dgeesaman likes this.
  4. Kevin in Ohio
    Kevin in Ohio
    You might also consider High tensile fence with reusable ratchets. I've used them before on stacks and thing and they work well. Thin piecs on edge distribute the load and most farm stores carry the stuff. Ratchets are about $3.00 but you'll never hurt them.
    HDRock and Certified106 like this.
  5. FarmHand78
    FarmHand78
    South East Iowa
    Poly with the clips is the way to go, the poly you seal is a PITA to work with. I use metal banding at work, and hate it.
    When banding on pallets make sure to crib the ends, or use 2x4's to help hold the square shape, other wise the stacks will just go egg shaped when you go to move them.
    schlot and dgeesaman like this.
  6. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Crib the ends on the bottom too? I figured i would stack the top a little roundish on purpose just for that.
    David
    FarmHand78 likes this.
  7. FarmHand78
    FarmHand78
    South East Iowa
    Just the sides need cribbed or use the 2x4's to brace. One other thing to watch is not putting the band under the pallet, to keep from breaking the band, poly does not stand up to abrasion very well.
  8. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    My concern with banding like that is as the wood shrinks you would have no way to tighten it since you need to crimp it to keep it tight. If you're only talking about a few skids I would think like 1" ratchet straps might be better..
  9. My IS heats my home
    My IS heats my home
    Albany, NH
    I was thinking the same thing, +1
  10. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I think the buckle type connectors can be retightened.
    Nylon strapping will not survive the UV exposure. Plus they would get expensive.
  11. Sinngetreu
    Sinngetreu
    North Central Iowa
    You could go with cheap horse wire and tighten it as it goes. If you search horse wire knots on Youtube, you can get some cost effective ideas. The ratchets that Kevin brought up are top notch, but it can be done without it if the price is a concern.
