Straight gassed BR600
Discussion in 'Chainsaws and Power Equipment' started by basod, Apr 27, 2015.
  1. basod
    basod
    Mount Cheaha AL
    We have one at work for blowing gravel off drives and such.
    Coworker decided to use it and when it ran out of gas he filled it with regular gas, ran for 15-20mins....came back to the shop asking why the cap was leaking gas.
    As I tried to get the flippy cap aligned I noticed the gas was kind of yellow - asked and he said he just fueled it up:headbang:
    Somehow another gorilla managed to overclock the twist in the flippy cap - not sure how but it was out 30deg or more?
    Sent him to the dealer for a new cap and some 2-stroke oil.
    After a drain and prime I got it running and it'll fire on the first pull. No compression check yet but it feels weak.
    When it dies I hope to convince management a new blower is in order(powerplant money) and the old blower comes home for new engine:D clamshell didn't search too hard but doesn't seem like much aftermarket is available? any leads?
    cnice_37 and Horkn like this.
  2. SquareFile
    SquareFile
    somewhere
    Those are notorious for exhaust valves breaking.
  3. basod
    basod
    Mount Cheaha AL
    2-stroke versions?
    Horkn likes this.
  4. Horkn
    The only valves on 2 strokes I know are power valves, and I've only seen those in motorsports 2 strokes.
  5. SquareFile
    SquareFile
    somewhere
    I didn't know there was a two stroke version. I've worked on the 4-mix
    XXL and basod like this.
  6. basod
    basod
    Mount Cheaha AL
    there are 4-stroke versions of the bR600 available now - may be where roundfile was coming from:wacky:
    Horkn likes this.
  7. basod
    basod
    Mount Cheaha AL
    probably why I can't find any aftermarket 2-strokes for it - clamshell in a "pro-grade" backpack blower
    XXL likes this.
  8. basod
    basod
    Mount Cheaha AL
    anyways how does anyone manage to change the alignment of the flippy cap?
    cnice_37 likes this.
  9. cnice_37
    cnice_37
    I'll trade you a toasted Echo handheld blower? My 5 yr old was happy as could be blowing off the walkway and just stopped. Seized, p&c are junk, but I only paid $30 for it 3 years ago. I didn't detect any signs of an air leak so I guess my blower tuning ear.... blows :picard:
    Horkn and basod like this.
  10. SquareFile
    SquareFile
    somewhere
    Are you positive its 2-stroke? Just odd to me a model number would be the same if two totally different engines.
    XXL and Horkn like this.
  11. basod
    basod
    Mount Cheaha AL
    The first blower I ever ran was an echo -good story:
    I used to hand sweep all the greenhouses(150-200') back on the farm, boss picked up an Echo blower one spring and said try this out.
    Well the wind was blowing(and I'm a dumbass 14-15yo) so I closed the doors and went to town on hands and knees cleaning the heck out of that greenhouse.....get down towards the end and he comes down to see my progress - yeah "GREENHOUSE GAS" the entire place was filled down to within 6-7' with 2-stroke smoke:doh: - good thing I was working on the floor or I might not be here today;)
    XXL, Deacon, Stephiedoll and 3 others like this.
  12. basod
    basod
    Mount Cheaha AL
    Pretty sure, no oil fill for the crankcase that I could see.
    I know most of the 4-strokes still require mix
    Mag Craft likes this.
  13. SquareFile
    SquareFile
    somewhere
    Stihl 4-mix don't require crank case oil. Mix only.
    XXL, basod and Cut4fun like this.
  14. Cut4fun
    Cut4fun
    OHIO Redneck
    :whistle::yes:
    XXL likes this.
  15. basod
    basod
    Mount Cheaha AL
    learned something new thanks:yes:
    Another coworker that has since retired bought this blower(plant money) it's under 6yo - not sure if that changes anything?
    It is damm quiet - maybe I'm in the wrong and it is a 4cycle? or the holes in my chainsaws mufflers are too big:loco: :crazy:
    XXL likes this.
  16. Cut4fun
    Cut4fun
    OHIO Redneck
  17. Fanatical1
    Fanatical1
    It's 4mix. Uses 50 to one fuel mix, is a 4 stroke, has valves but no crankcase oil. Good luck with the repairs.
  18. Cut4fun
    Cut4fun
    OHIO Redneck
    The
    STIHL 4-MIX engine
    features
    mixture lubrication and must be run on a
    fuel mixture
    of gasoline and engine oil.
    It operates otherwis
    e on the 4-stroke
    principle
    This engine is certi
    fied to operate on
    unleaded gasoline and the STIHL two-
    stroke engine oil at a mix ratio of 50:1.
    Your engine requires
    a mixture of high-
    quality gasoline and two-stroke air
    cooled engine oil.
    Use mid-grade unleaded gasoline with a
    minimum octane ratin
    g of 89 ((R+M)/2)
    and no more than 10% ethanol content.
    Fuel with a lower
    octane rating may
    increase engine temperatures. This, in
    turn, increases the risk of piston seizure
    and damage to the engine.
    The chemical composition of the fuel is
    also important. Some
    fuel additives not
    only detrimentally affect elastomers
    (carburetor diaphragms, oil seals, fuel
    lines, etc.), but ma
    gnesium castings and
    catalytic converters
    as well. This could
    cause running problems or even
    damage the engine. For this reason
    STIHL recommends that you use only
    high-quality unleaded gasoline!
    Gasoline with an et
    hanol content of
    more than 10% can cause running
    problems and major damage in engines
    and should not be used.
    The ethanol content i
    n gasoline affects
    engine running speed – it may be
    necessary to readjust
    the carburetor if
    you use fuels with
    various
  19. basod
    basod
    Mount Cheaha AL
    XXL likes this.
  20. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    This Cub Cadet trimmer I was given last week is 4 cycle with crankcase oil. Went to my local dealer and I ordered a new trigger for under $2.
    basod likes this.
