STP Bar and Chain Oil
Discussion in 'Chainsaws and Power Equipment' started by JW IN VA, Feb 7, 2023.
  1. JW IN VA
    JW IN VA
    Virginia mountains
    Anyone use STP brand?
    Cheapest I've found.
    12.99 per gallon. Closest is TSC at 15.99 on sale.
    Stihl and Husqvarna run 24.99
    Screwloose likes this.
  2. buzz-saw
    buzz-saw
    Ct.
    Ouch , $15.99 , and it just keeps climbing.
    Never used it myself so can't really be of much help.
  3. redneckhillbilly
    redneckhillbilly
    NW MT
    I think thats the same stuff autozone sells, I've ran it before and it worked fine for me.
  4. RCBS
    RCBS
    Over here
    Rural King anywhere around you? $8.99 gallon right now for CAM2.
    I'm sure STP is fine.
    Barcroftb, TurboDiesel and Screwloose like this.
  5. billb3
    Autozone and Harbor Freight around here only have STP in quarts.
    I haven't bought bar and chain in a quart in a very long time.
    iirc, it's a weird red color, more like transmission fluid.
    KSPlainsman and Screwloose like this.
  6. Screwloose
    Screwloose
    Looks like everyone is in the bar and chain lube game.
    Barcroftb likes this.
  7. KSPlainsman
    KSPlainsman
    Kansas
    Jump on Walmart.com and get some Black Max. I think it's $10/gallon shipped, at least to where I am.
    RCBS and Screwloose like this.
  8. KSPlainsman
    KSPlainsman
    Kansas
    Kinda funny.......Napa's bar and chain oil used to look like bar and chain oil and was tacky. The past year or so, it's been red and smells just like ATF too.
  9. KSPlainsman
    KSPlainsman
    Kansas
    I should've looked first, but I just checked the oil I mentioned and it's now $14/gallon.
  10. Cheepbeer
    Cheepbeer
    NW Ohio
    Walmart canola oil's $9.12 a gallon. I might try some, but I've got about 6 gallons of bar and chain I picked up a couple years ago for 4 or 5 bucks.
    Screwloose and Barcroftb like this.
  11. Lehman
    Lehman
    Minnesota
    Canola oil gums pumps up ect, it also doesn’t stay on the chain well so your lubrication properties are less. Bar oil up here is 8-10$ a gallon maybe a little more so I’ll just keep using it.
  12. Barcroftb
    Barcroftb
    The Mitten
    I’ve run canola oil in my climbing saws for quite a long time now. No ill effects observed. After all before those Canucks convinced the rest of the world it was a food oil it was used as a machine oil. Canola is fine but other veggie oils will eventually become solid/rancid and wreck the saws oil pump. You could definitely pick some up and mix half and half with bar oil to stretch your supply on hand.
    Screwloose and eatonpcat like this.
  13. Lehman
    Lehman
    Minnesota
    Must have been other vegetable oils they used then because I had to actually heat the pump up to get the waxy plug removed from it.
  14. JD Guy
    JD Guy
    Upstate SC
    Was in Northern Tool this week and Stihl Synthetic was $26.99 and orange was 24.99. Picked up a gallon of orange cause I’m down to less than 1/2 gallon. Sure wish I would’ve stocked up a lot earlier :doh:
    I am going to be on the lookout for some of the other brands y’all have mentioned.
  15. Barcroftb
    Barcroftb
    The Mitten
    I’ve been using Canola oil in my top handle saws for over 3 years now Chris no trouble, and I’m not the only one I know who does so. Other veg oils 100% will plug the oil pump as you say.
  16. JW IN VA
    JW IN VA
    Virginia mountains
    I've used canola straight and mixed in cold weather. No problems.
    I did switch back to bar oil when the weather warmed.
