Stovepipe compatability
Discussion in 'Modern EPA Stoves and Fireplaces' started by bushpilot, Jul 13, 2016.
  1. bushpilot
    bushpilot
    Eastern Washington
    Can I use Supervent double wall stovepipe from the stove to the Duravent chimney?
    The stovepipe will be this, plus maybe another 24" section. (Is an adaptor needed between the pipe and the 30-NC stove?)
    Shop SuperVent 6-in L x 6-in Dia Black Insulated Double-Wall Steel Stove Pipe at Lowes.com
    The chimney will begin at the cathedral ceiling with this kit, and will be all Duravent from there up.
    DuraVent DuraPlus 6 in. Triple-Wall Basic Through-The-Ceiling Chimney Stove Pipe Vent Kit-6DP-KBSC - The Home Depot
  2. brenndatomu
    That should work. The double wall should drop right into the stove. You will need an adapter to go from the stove pipe the chimney...if the kit doesn't already have one.
    Have you considered adjustable stovepipe? Makes cleaning easier...unless you are gonna just pull the stove baffle out to clean...
    tfdchief likes this.
  3. Highbeam
    Highbeam
    I clean the vertical pipe above my NC30 without removing the pipe. The baffle is very easy to remove and the large firebox makes the use of a sooteater very easy for bottom up cleaning.
    papadave, bushpilot and brenndatomu like this.
  4. tfdchief
    tfdchief
    Tuscola, IL
    I agree!!! Makes cleaning easy.
