Stove was a sqealing
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Hoot23, Nov 10, 2013.
  1. Hoot23
    Hoot23
    Alfred, ME
    Awoke yesterday morning to a sqealing stove every time the auger would turn. I just replaced the auger motor 2 weeks ago because the bearing was sqealing. This time it was coming from inside the tube. I clean the fines box during my monthly cleaning, but I guess I'm not getting it all cause the tube was full of fines. Vacuumed it all out, slapped it back, and it runs like it did when we first got it.
    Beware of the fines folks.
  2. mepellet
    mepellet
    Your auger tube was full of fines? I believe that in my stove the fines get pushed through the aguer tube with the pellets. Maybe I am missing something though.
  3. Hoot23
    Hoot23
    Alfred, ME
    It was further back where they drop into the tube. When I take the fines cover off I reach up in there with my fingers and a small vac attachment and try to get all the fines I can. But I'm not getting everything there was a lot in there. I just gotta do better job I guess
  4. subsailor
    subsailor
    Winthrop, Maine
    When I clean mine, there are fines but I've never seen a staggering amount. It's usually not full. Mine seem to get pushed through the tube like mepellet said.
  5. imacman
    imacman
    Denver, NC
    And this was what brand of pellets?
  6. Hoot23
    Hoot23
    Alfred, ME
    I'm burning LaCrete. Hardly any fines or dust in the bags. But I do hear a lot of grinding and pellets breaking.
    But, woke up this morning to it sqealing again. Don't know what else to do for it. But I need to do something, wife is driving me crazy with the complaints.
  7. smoke show
    smoke show
    Pittsfield, Wi
    Hello,
    Dry moly is a miracle cure. ;)
  8. Hoot23
    Hoot23
    Alfred, ME
    TSC carry that.
  9. Kinsman Stoves
    Kinsman Stoves
    Brookfield, Ohio
    make sure you seated the auger correctly. Use some lube on the "sealed" bearing. No one likes a dry pole.
    Eric
    will711 and Hoot23 like this.
  10. Hoot23
    Hoot23
    Alfred, ME
    Is dry moly and the dry Teflon lube the same stuff.
  11. Kinsman Stoves
    Kinsman Stoves
    Brookfield, Ohio
    I use a brand called Tri-Flow. Been using it for a few years. I guess it is kinds like WD-40 on steroids. I hit noise bearings with it and tends to last 6 months so I guess it works. I can also replace bearings but if this works might as well wait till the freeze up or pay up $$$$.
    Eric
    NortheastAl likes this.
  12. Hoot23
    Hoot23
    Alfred, ME
    Thanks Eric
  13. NortheastAl
    NortheastAl
    Putnam County NY
    Don't use any product like WD40 or oil that can attract fines and dust. A dry lube like pure silicone, moly, Teflon and even graphite in the tube can be useful. The fines should get pushed out the tube. I had a top drop and the tube never got filled with fines. They were always sent out the drop end. I would also see if your pellets are not self destructing or getting crushed in the tube.
  14. NortheastAl
    NortheastAl
    Putnam County NY
    For motors and bearings, yes, this works. I used a high temp Teflon oil on my blower and exhaust motors.
  15. Hoot23
    Hoot23
    Alfred, ME
    I went to my dealer this morning and he thinks it's the auger. He gave me a new one, but it looks totally different than the old one image.jpg
  16. Hoot23
    Hoot23
    Alfred, ME
    I picked up some graphite spray, that's ok to spray in the tube
  17. Hoot23
    Hoot23
    Alfred, ME
    Great, definitely not the right auger, I'll be back. BS!
  18. gbreda
    gbreda
    NH
    Ouch :confused:
  19. smoke show
    smoke show
    Pittsfield, Wi
    spray the graphite on your dealer. ;)
  20. Hoot23
    Hoot23
    Alfred, ME
    Up and runnin. New auger, all cleaned up. Removed the slide plate while everything was off. Hope we're good for awhile. Thanks for the advice.
