Stove pipe / chimney sweep tool preference?
Discussion in 'Axes, Mauls, and Hand Saws' started by Sean in the woods, Nov 4, 2020.
  1. Sean in the woods
    Sean in the woods
    UP, Michigan, USA, Earth, Sol, Orion–Cygnus Arm
    Hi Folks,
    After paying $265 for a chimney sweep to clean our stove pipe, I thought about doing my own, so I searched for tools (like ya do). I found SootEater and Flexi Chimney Rods, along others. They each seem to believe they are the best and the only.
    Those of you who clean your own:
    What tool do you use, what do you like about it and what would you change?
    Thanks, again.
    Sean
  2. CoachSchaller
    CoachSchaller
    Southeast Michigan
    I use a fiberglass rods and a nylon brush. I take off the slip pipe that connects my stove to the ceiling adapter and clean from the bottom. It is what I have and I am not sure it is any better than any other method.
  3. Warner
    Warner
    Fiberglass rods and a brush from the roof. Probly not the best solution but it works for me.
  4. brenndatomu
    I used to use a standard chimney brush and rods...then switched to the Soot Eater some years back, I like it, I think it does a better job than the brush.
  5. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Soot water here as well. Pleased with the job it does, and no need to get on the roof.
  6. Slocum
    Slocum
    North Central Indiana
    I use the soot eater from the bottom up. It does a great job. You can concentrate on a area with the soot eater. The last top 4’ of my chimney is always the worse. With my old nylon brush I would have to pull it the full length for the bristles to change direction.
  7. wood and coal burner
    Quakertown,PA
    I tie a bit of mule tape (polyester cable pulling cord) but any good rope would do onto a pant leg stuffed with golf balls. Drop it down the chimney and pull it up and down a few times. It is not abrasive and lets old jeans have a new life. Wire ties on the ends keep the golf balls in their place. Chimney Cleaner.jpg
  8. Mag Craft
    Mag Craft
    South East Wyoming
    I have the soot eater also and do mine from the roof down. I always shine a flash light down the pipe when done to see how it looks. Always nice shiny metal. It has paid for itself.
    T.Jeff Veal, In the Pines and Horkn like this.
  9. Sinngetreu
    Sinngetreu
    North Central Iowa
    In the past I used a chunk of chain on paracord from the roof, but after a fall I am planning on using this from the bottom. We shall see if it works well.
  10. Horkn
    Same here. I use a nylon brush since I've got a SS liner
  11. blacktail
    blacktail
    PNW
    I bought a sooteater right after I had my insert installed. Still using it to clean from the bottom up 9 years later. No need for me to go on the roof and it takes hardly any time at all. Can do it in any weather or after dark. I've come home at 11pm and cleaned my liner.
  12. Sean in the woods
    Sean in the woods
    Thanks all.
    Just had the new stove installed yesterday and made sure that the flue would be accessible for cleaning. Looks like a soot eater is in my future.
  13. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    +1 on soot eater. I needed two kits to get through the pipe on my lower level. It has two 45 degree bends in it and the soot eater took it in stride. I couldn’t get a standard fiberglass rod through the bends.
    T.Jeff Veal, Horkn and In the Pines like this.
  14. Sean in the woods
    Sean in the woods
    Welp, looks like Ima ordering a soot eater so I have it before I need it.
    Again, Thank You All.
    Sean
  15. Dstrick
    Dstrick
    Maple Valley, Washington
    Is it the Gardus brand?
  16. Sean in the woods
    Sean in the woods
    Yes, I think that Gardus is the company that makes the SootEater. They come in the original black pole and the newer white pole. The white pole is more flexible and so, can get through bends better. That’s what I ordered.
  17. brenndatomu
    You got a white pole kit? I heard they used to have those, but was of the understanding they were no longer made (except for the dryer vent cleaner kit) EDIT: Huh...yeah I see the white ones now. I would say no need to spend the extra money on those unless you have a situation where you need to go through a 90* turn...the black poles do fine on 45*s.
    Yes, made by Gardus...a HY-C company.
  18. Sinngetreu
    Sinngetreu
    North Central Iowa
    I just bought a soot eater and it looks like the golden ticket. blacktail summed up my thinking pretty well.
    T.Jeff Veal, Horkn and brenndatomu like this.
  19. blacktail
    blacktail
    PNW
    Yes. Mine has the black rods.
    T.Jeff Veal likes this.
