Stihl weed wacker issues....fs90r
Discussion in 'Chainsaws and Power Equipment' started by bocefus78, Apr 7, 2017.
  1. bocefus78
    bocefus78
    Indiana
    damm thing let me down today. After countless years of service it left me hanging. Clutch has been wasted for years. If it idles, it spins the head.
    Well.....not anymore. Hands will spin it but with resistance. Throttle won't spin it. Motor isn't the issue....she purrs.
    Wth happened?
    My back-up fs90r got me thru the day but it don't run worth a fugg comparatively.
    Anyone been here before? This is a heavily used commercial rig. Only parts I've replaced are triggers and primer bulbs.
  2. Canadian border VT
    is it a split shaft?
    bocefus78 likes this.
  3. bocefus78
    bocefus78
    Indiana
    Negative. Straight solid.
    Problem almost has to be clutch related
  4. Canadian border VT
    bet it's the gear in the pole that transfers power from motor to head.. is that what your call in a clutch,,
    Ashwatcher and bocefus78 like this.
  5. bocefus78
    bocefus78
    Indiana
    I'll do some disassembly tomorrow. I'm on the hops right now. U saying this is where the motor meets the shaft? I need a starting place here.
    Ashwatcher likes this.
  6. Screwloose
    Screwloose
    Have you been regularly greasing the gearbox on the cutting head ?
    Ashwatcher and TurboDiesel like this.
  7. TurboDiesel
    I'm guessing the clutch finally came apart
    Screwloose likes this.
  8. Screwloose
    Screwloose
    I'd take everything from the purring engine (and maybe that to) to the guard apart and overhaul it. Not much to it. Fix the wasted clutch, Clean everything, replace worn parts and show her some love.
  9. bocefus78
    bocefus78
    Indiana
    Update 1: clutch is fine. Head is fine. Canadian border VT is this the part you were talking about? If so....you were right. It appears to be a bearing that had crapped out. Can't figure out how to remove it though. Need more coffee I guess....or a bigger hammer :)
    Off to the stihl dealer.....vaseline in hand.
    Oldman47, Canadian border VT and RCBS like this.
  10. Screwloose
    Screwloose
    Tons of fretting corrosion on that. Looks like a set of clutch drum bearings and maybe even a drum to me.
  11. RCBS
    RCBS
    Over here
    Looks like an external snap ring holding it in there?
    Mag Craft likes this.
  12. Canadian border VT
    yup the shafts bearing... sorry I won that bet... once you replace it it's good for as long as last time... at least mine is so far...
  13. bocefus78
    bocefus78
    Indiana
    She's fixed. Good thing I took the Vaseline in the dealer...thats a $27 bearing!
  14. Canadian border VT
    :yes:
    it's good for a while now!
    Eric VW likes this.
  15. MasterMech
    o_O
    Good thing it's making you money....
    :emptywallet:
  16. bocefus78
    bocefus78
    Indiana
    Yes sir. Thats part of the game unfortunately....as you know.
    Thing is....it was just a ntn bearing that if I knew the # beforehand and had time, I could've gotten much cheaper. Such is life....it needed fixed Today.
    "Done, done and I'm on to the next one...."
  17. fuelrod
    fuelrod
    Western Maine
    I have an old FS-90 that I bought new years ago, like over 20! Although it doesn't get a ton of use, every year it just keep's going. I run a 12" carbide chopsaw blade on it for saplings & tree's up to about 3". It's worth the $27 bearing for sure!:thumbs:
    I bet I just screwed myself with that statement:rofl: :lol:
  18. Eric VW
    Why ya say?:whistle:
    Canadian border VT and fuelrod like this.
  19. lukem
    o_O
    And your occasional zombie. Probably. Maybe?
    fuelrod and Eric VW like this.
  20. Eric VW
    :thumbs:
