Stihl RM or RS
Discussion in 'Chainsaws and Power Equipment' started by Certified106, Mar 26, 2015.
Which Do You Prefer?
  1. Stihl RM chain
    8 vote(s)
    15.1%
  2. Stihl RS chain
    30 vote(s)
    56.6%
  3. Other
    5 vote(s)
    9.4%
  4. Have both but use them for specific purposes
    10 vote(s)
    18.9%
  1. Certified106
    Certified106
    In The Hills
    So I bought two brand new loops of chain a while back with the intention of testing them side by side. One loop was RM and one loop was RS. After trying them side by side I have found I much prefer the RS chain over the RM. I was just curious what other people liked and why.
    Shawn Curry and clemsonfor like this.
  2. prell 73
    prell 73
    ia
    I think theirs chain cuts faster and stays sharp longer.imo
  3. basod
    basod
    Mount Cheaha AL
    RSC - mine are older before the C was dropped.
    file with 10-15deg uprake/sideplate and they get even better:saw:
  4. Cut4fun
    Cut4fun
    OHIO Redneck
    Just so you know. RS was before RSC and then the C was dropped later to go back to RS. ;)
  5. Evanrude
    Evanrude
    Byron, MI
    Take that RS to cut some fence row shagbark and tell me you still prefer it :p. I like RS for working in the woods, but anytime I'm cutting fence rows, field edges or yard trees, I prefer RM.
  6. Certified106
    Certified106
    In The Hills
    I cut Shagbark with RS frequently. Curious what your reasoning is. I am just trying to learn as much as I can about the different chain styles.
  7. basod
    basod
    Mount Cheaha AL
    thanks for the lesson:thumbs:
    clemsonfor likes this.
  8. DexterDay
    DexterDay Administrator
    Northeast Oh
  9. MasterMech
    It's not the shagbark, it's the fence row that it's in that kills chain. RM will never cut as fast as RS but it will take abuse that will stop RS in its tracks.
  10. Evanrude
    Evanrude
    Byron, MI
    Right. However, I believe shagbark has more potential to catch dust than most trees. At least it seems that way when I cut them next to other trees in fence rows.
  11. StihlHead
    StihlHead
    The wild west
    Also the RS that was 'before' was/is different chain than RS 'after'. RSC is the same as the new RS.
    Zaat is juzt to keep us Amerikans confuzed by zee Germans. <click>
  12. StihlHead
    StihlHead
    The wild west
    RS is full chisel, RM is semi chisel. Round filed, RM will stay sharp longer than RS, especially in dirty conditions. RS will cut faster than RM, but usually dull faster because of the sharp points on the cutters. Square filed RS will cut even faster but it will also really dull fast as the edge of the points are really thin. I use both, and swap them out depending on conditions. Dirty conditions or near the ground, RM. Clean wood, RS. Same with PM and PS low profile. I am waiting for PMS to come out for cutting during 'that time of the month'.
  13. Cut4fun
    Cut4fun
    OHIO Redneck
    Yep, I just didnt want to mention it, then have to explain that too. ;)
  14. bogydave
    Of the 2 choices , I prefer RS over RM, (for my conditions)
    but went to LPX & am pleased with it's performance for me, (cutting 90% green birch)
    Some spruce, which seemed to dull the RS faster than the LPX.
    RS is faster cutting , but dulls faster than RM.
    Found RS & RM 3 to be good all around chains too.
    I went to the Oregon LPX for felling, liming, bucking clean wood .
    Trying the LPG this year, so far have noticed a little less kickback when liming, which is kinda nice.
    LPX is less expensive , sharpens better & last longer for my conditions.
    (I seemed to have to file more metal off the RS , than the LPX, to get it back to sharp, LPX lasts longer than RS, for me)
    Have about 20 of various 20" chains. May not need to buy anymore. Last year I cut 10 cord with an LPX, & it's still over 50%.
    Got 5 LPX & 5 LPG for $15 each. With just these, I should be able to cut over 100 cord (or 15+ years worth of wood).
    Hope to be "snow birding" way before I use them up :)
  15. Machria
    Machria
    Long Island, NY
    Can you explain more detail on that?
    Shawn Curry and splitoak like this.
  16. $ooline
    $ooline
    WI
    Instead of filing level across the tooth, you give it a 10 degree or so "up" angle is what he's saying....so tilt the file a little when filing from the inside out. Some file guides have a bend on the tip to get you in the ballpark of how much this tilt would be. I'm pretty average at hand filing but getting better I think so can't comment on how effective this is. From what I know alot of the hand filing deal is keeping every tooth as consistent as possible whatever angle you use, say 30 degrees across, then if you can consistently put a 10 degree up on every tooth you're ahead of the game.
  17. splitoak
    splitoak
    jefferson co wv
    RS 30 degree angle straight across:D
    Shawn Curry, StihlHead and $ooline like this.
  18. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    RSF :D28 and 25" Usually only cut standing trees.
    Shawn Curry likes this.
  19. basod
    basod
    Mount Cheaha AL
    it's easy to do with a Granberg style file jig. handiest $25 you'll ever spend - file all your chains at once and change in the field
    Instead of keeping the file at a perfect T(90deg) to the bar and 30deg to the chain tooth.
    The file is 10/15deg from the normal T(down on the right side of the file) and still 30deg on the chain tooth.
    On a new chain it takes ~5-6 passes to bring a full glint to the cutter edge, and then clean out the gullet from the factory grind.
    If you get into the straps a touch no big deal
  20. CTYank
    CTYank
    CT Panhandle
    Maybe some of us are not in tune with Stihl's codes. You could tack in some communicative ones, like "SC" or "RdCh". No need for translation then.
    I've a few loops of Oregon 72LGX for each of my big bars (vice LoPro), and typically it cuts very well for up to two tankfuls in clean wood. At about that point you can sense it getting dull with the ol fingertip-test. Shortly it'll be spitting dust. Catch it around there with Granberg clamp-on file guide and a couple strokes/tooth will do it nicely & precisely. (It's in the bag.)
    I like semi-chisel so much more for its edge longevity, I got a reel of WoodlandPro 30SC. On occasion, that's kept cutting where the LGX would have been making smoke-signals. IMO. The 30SC makes cutting easier in many ways: chain, bar, engine, me. I really appreciate it in the black locust we've been cutting on one site- must have a lot of silica in it. Way tougher than on a site a couple hundred yards north.
    Both the Oregon and WP chains cost way less than any local Stihl dealer's price, most especially off a reel. Frawley's or Bailey's- pick one.
