Stihl MS291 muffler bolts
Discussion in 'Chainsaws and Power Equipment' started by Chilidawg, Nov 11, 2023.
  1. Chilidawg
    Chilidawg
    MI
    Has anyone ever had one of these shear off in the cylinder? I was cutting an ash log this afternoon and the muffler fell off the saw. One bolt backed out of the cylinder entirely and the other sheared off flush.
    I returned it to the selling dealer and they were able to remove the remnants and reassembled the saw.
    Is this a common occurrence? Does anyone have any idea what the cause might be?
    Thanks in advance
    brenndatomu and eatonpcat like this.
  2. Chud
    Chud
    NC
    It can happen. It’s good preventative maintenance to occasionally check for loose fasteners. I have lost a dog nut and bolt and had nuts and bolts loosen up on dogs. I’m sure I’ve lost muffler bolts before too, so at a minimum I’ll try to wiggle the muffler.
    Ohio, brenndatomu and eatonpcat like this.
  3. brenndatomu
    The second one broke off because of the vibration and stress that it seen after the 1st one backed out...something like a muffler being held by one side only will always be a recipe for broken parts.
    Ohio and Eggshooterist like this.
  4. Chilidawg
    Chilidawg
    MI
    Thank you guys for the feedback. I'm grateful
    Ohio, Eggshooterist and brenndatomu like this.
  5. Ohio
    Not Ohio
    I added a new felling dawg to my XS362 and used loctite, I’m never going to remove it anyway. Not sure if you would want to do this on muffler bolts with the added heat it might not work that well anyway.
    brenndatomu, Eggshooterist and Chud like this.
  6. Chilidawg
    Chilidawg
    MI
    That was my thought regarding LocTite. That's probably the hottest part of the saw, and what loosens LocTite? But having thought about it a couple minutes, maybe a couple external shakeproof washers, and the suggestion of checking them before every use. Not like it's hard...
    brenndatomu and Ohio like this.
  7. brenndatomu
    They have high temp loctite...
