Stihl MS-290 Questions.
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Nov 14, 2015.
  1. Kimberly
    Kimberly
    The Kangaroo State
    The last time I used the Stihl MS-290 when first starting it would do this funny sound and cut off; sort of like opph or whatever; guess I should take a video of it so you can really know, when you try to increase the engine speed. It would start again and I would have to play with the throttle a bit; pressing a bit and releasing when I thought it was going to do it again, and then it would run fine. However, I noticed the chain would want to continue to turn at idle, which scares me. What is causing this and how do I fix it?
    Eric VW likes this.
  2. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    That first sound is called the burp. This is how I start mine: full choke, pull until it burps. Half choke-- one or two pulls it is running, probably spinning. Give it a little gas and then spinning stops and I'm ready to cut. Could always start it with the chain break on, that's what I do if I'm in kind of tight quarters.
    OhioStihl, Chvymn99 and Eric VW like this.
  3. Kimberly
    Kimberly
    The Kangaroo State
    No, this is not normal operation. I know about starting the saw; the choke first, the first little aputter, then open choke. I try to explain better.
    After starting the saw and it is running, when I try to apply throttle it does the funny sound, omph, or something and will die. I have to bump the throttle a few times making sure not to let it does the noise thing because it will die. Once I get pass that it will run and I can cut. The chain often continues to rotate around the bar when I set it down and leave it running while doing something like adjusting a log; it will sometime stop rotating at idle and just jerk a bit. Do I need to have the carb adjusted or is this a problem with the fuel or what?
    pantelis likes this.
  4. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    Sound like a few turns of a screwdriver and you will be good to go. DexterDay or MasterMech should be able to help you more.
    Chvymn99 likes this.
  5. MasterMech
    It sounds like it needs some adjustment and/or possibly minor repair. Without a video or having the saw in hand, it's tough to say exactly what.
    clemsonfor and pantelis like this.
  6. Kimberly
    Kimberly
    The Kangaroo State
    I really love my saw and I won't forget the kindness of the folks here that helped me to get it. I don't know much about adjusting the carbs on chainsaws. Are there some videos or instructions to guide me?
    clemsonfor likes this.
  7. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    Brian, didn't you make one of these? I remember viewing it before I tuned my 250.
  8. Pyroholic
    Pyroholic
    mid michigan
    Sounds like some Skype time between Brian and the 290 are in order. Lol
    I believe this is the video you speak of griz.
  9. pantelis
    pantelis
    Europe
    The saw doing this omph noise and start die because the carburator needle stuck for a moment
    If the saw do the same and at full throtle adjust the H screw
    try to control the chain from the LA screw , if not see the clutch , if not test the saw for leaks .
    if the saw work good at full throtle and not at idle is mark that have leaks
    hope i help you
  10. MasterMech
    I'm surprised that vid is helpful to novice tuners. It's pretty technical, no close-ups, and the music is awful. :picard:
  11. HDRock
    Have you checked to see if your air filter is clean?
    clemsonfor and bobdog2o02 like this.
  12. Kimberly
    Kimberly
    The Kangaroo State
    I took the cover off and brushed it lightly with a toothbrush.
  13. HDRock
  14. Pyroholic
    Pyroholic
    mid michigan
    It is a little technical. I had never tuned before and felt confident in trying it out after watching. I watched several times, listened, took notes, and dove in. That was all before I had a Tach. I was tuning cautiously rich. That is a good place to start. After I got a good tach I started tuning a little leaner to somewhere between the rpm specs and what my ear said.
    It is a great video. For me the most helpful party was hearing the sounds that everyone talks about when tuning by ear.
    clemsonfor, HDRock, Chvymn99 and 2 others like this.
  15. colin.p
    colin.p
    Ottawa Canada
    My 455 starts good and idles good, but until it warms up, it bogs considerably. It makes a funny "blurp" type noise and then, when warm, runs fine. Is that similar to what you are seeing?
    clemsonfor and Eric VW like this.
  16. Boog
    Boog
    Where my spirit is free
    That vid was extremely helpful to me when I was starting out. If that chain is still moving when you are all tuned and idled down you may need to replace the springs on your clutch.
  17. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I think that is what I am seeing. It only started doing it when I was cutting the red oak. Could this be because the weather has turned colder? Colder air is denser. I am guessing I just need to tune the carb a bit.
    clemsonfor, pantelis and Eric VW like this.
  18. dusky
    dusky
    Pittsburgh
    I dont have a Stihl, but on my Echo under the cover that houses the air filter there is a little passageway with a removable gate. In cold weather you remove the gate to let more air in. Does anyone know if her saw would have one of these?
    clemsonfor, Horkn, pantelis and 2 others like this.
  19. Kimberly
    Kimberly
    The Kangaroo State
    MMM. I did download a pdf for the manual; I should go read that again.
    Eric VW likes this.
  20. Eric VW
    You go, Kimberly! You can do it!
