STIHL MS 261 no compression
Discussion in 'Chainsaws and Power Equipment' started by Michael Fesler, Dec 28, 2018.
  1. Michael Fesler
    Michael Fesler
    Oklahoma
    Local guy has a Stihl MS261 for sale. Says it has no compression and doesn’t run. Comes with 20” bar and 3 chains (2 new). Asking $125.
    What’s it worth?
    What’s it cost to rebuild?
    amateur cutter, Hammy and TurboDiesel like this.
  2. Casper
    Casper
    I buy them at $50 from a tree service in that condition. Several times it has been due to them torquing the sparkplugs to the point of stripping. Save a plug works pretty good. I'd be hesitant over 75, I've seen scorched wrist pin and main bearings in a couple.
  3. TurboDiesel
    Would probably be ok if the saw is in ok condition. If its rough, hit him a little low.
    2 chains are worth $40
    Chaz, amateur cutter, Hammy and 2 others like this.
  4. Mag Craft
    Mag Craft
    South East Wyoming
    I would at least price a new piston rings and a cylinder. Then see if it is worth 125.00. It could be something more wrong or something less but at least it gives you starting point and a bargaining tool. And do not forget your time to do all the work.
    A lot of shops would probably charge more than the saw is worth.
  5. Michael Fesler
    Michael Fesler
    Oklahoma
    Where’s the best place to find the parts? This is all new to me.
    Chaz, amateur cutter and Hammy like this.
  6. amateur cutter
    Calling dall , huskihl , Armbru84 & a few others I can't think of right now. These guys will point you in the right direction.
    Hammy, Chaz, huskihl and 1 other person like this.
  7. dall
    dall
    West Virginia
    i get my parts from definitive dave he has or can get oem and aftermarket parts
    Hammy, amateur cutter, Chaz and 3 others like this.
  8. dall
    dall
    West Virginia
    have you taken cylinder off or even the muffler off ?
    Hammy, amateur cutter, Chaz and 2 others like this.
  9. dall
    dall
    West Virginia
    can you get us pictures if you do buy it
    i havent had to rebuild a 261 yet but id like to because i have a couple of them but i have rebuilt over 50 usually 150 to 200 bucks to rebuild with new bearings gaskets seals hoses and piston but being new some of that stuff may not be needed and possible it was straight gassed which would be a new piston and see if can clean the cylinder
  10. Michael Fesler
    Michael Fesler
    Oklahoma
    I was looking at parts and then put the kids to bed and someone else bought it. There will be another one sometime.
  11. Michael Fesler
    Michael Fesler
    Oklahoma
    Is he a member on here?
    Hammy and amateur cutter like this.
  12. dall
    dall
    West Virginia
  13. Armbru84
    Armbru84
    Sparta, Michigan
  14. huskihl
    huskihl
    $125 is a crapshoot. Sometimes free is a crapshoot, depending on what it needs. If it needed both a piston and cylinder, and bearings, you might into it for more than it's worth, even if doing the work yourself. Some of the 261's were notorious for wearing out the crank at the clutch drum bearing also.
    So it might have been a good deal if it didn't need much, but it's really hard to say without giving it a once-over
  15. Michael Fesler
    Michael Fesler
    Oklahoma
    I’m not losing any sleep over it. I probably need to figure out what to look for and how to actually rebuild before I take a $125 gamble on one anyway.
  16. huskihl
    huskihl
    I actually prefer buying a cheap saw that's advertised as scored. 9 times out of 10 the cylinder can be saved and all I'll need is a piston. Unless it had bad bearings, which in turn wore out the seals
    Hammy, brenndatomu, dall and 4 others like this.
  17. dall
    dall
    West Virginia
    same here
    but some people dont know what scoring is
    i bought a 460 that was told low compression but fuel tank was filled with bar oil and the decomp was pushed in
    i take chances and if would take more than saw is worth it becomes a parts saw
  18. brenndatomu
    I bought a Craftsman 4218 for $20...guy said the chain was locked up...I bet you guys can figure out what was "wrong" :rofl: :lol:
  19. dall
    dall
    West Virginia
    lol chain brake or a dry overtightened chain but id say the first guess is best
  20. brenndatomu
    Yup...it was fixed before I got to my car! I didn't feel bad either because I saw what was wrong right away, asked him if he had looked at it at all, he said he didn't care, just wanted rid of it...yes sir! :salute:
    amateur cutter, Hammy and huskihl like this.
