Stihl Kombi with Cultivator Attachment
Discussion in 'Chainsaws and Power Equipment' started by Marshel54, Jul 10, 2017.
  1. Marshel54
    Marshel54
    I am close to pulling the trigger on a Stihl Kombi unit. My main use would be brush cutting and cultivating.
    Anyone have this unit with a cultivator? Which model? Opinions please. I am a little concerned with power and weight on what I am trying to do.
    I don't know how big of unit to go with. Thinking about a 94R.
    Eric VW, Shawn Curry and XXL like this.
  2. Babaganoosh
    Babaganoosh
    Jersey Shore
    Brush cutting and cultivating ? I'd go with the 130 or 131. Lots of torque there. The negative is that it's a little heavier.
    If you are gonna use it professionally every day as a landscaper then go 94 maybe. Home use go 13_
  3. bocefus78
    bocefus78
    Indiana
    My fs90r will run the cultivator attachment I have, but the bigger the better if that's gonna be it's main gig.
    Canadian border VT, Eric VW and XXL like this.
  4. Will C
    Will C
    New York
    I bought the 130 and I'm glad I did. Very little more weight than the smaller units, but much more power. The 94 would be tempting because I am a 2 stroke fan, but no complaints about the 130 4-mix.
  5. XXL
    XXL
    Ontario, Canada
    I talked to my buddy who uses the rubber power sweep, which I think would be similar to running a cultivator and he went with the KM 130. works great for that but thinks it overkill for all other attachments like trimmer and blower.
    I like my KM 94R 2-stroke but not sure if it would enough for a cultivator. I'm going to try my buddies power sweep soon and compare my 94 to his 130.
    Will C, Eric VW and 94BULLITT like this.
  6. Shawn Curry
    Shawn Curry
    Western NY
    I can't really give an opinion on the power needed except to say, if you have soil like mine, you could do your entire garden with a chincy electric cultivator (what I did). I'm on a bit of a sand bar though - if you have lots of clay then the more power the better I'm sure.
    XXL and Eric VW like this.
  7. Canadian border VT
    yup got the 130 with cultivator ...limb saw... string ... and blade head.. it will not be short of power brother has a 90 I'm not enough for broom.. I only considered big motor I am 6 foot 220 it's not that heavy.. you will love that cultivator for removing tire ruts from lawn..
    oh why I only considered big was I put on 10 inch saw blade to remove brush tree at ground level... enough tork to make it whine touch sumac or up to 3 inch maple. they fall over.. 1 hour with tool 4 hours pickin up brush.. time for bonfire and drinks! any questions ask... mine is 130r split shafts combi unit.. brother got non split shafts (cause it only takes couple minutes to change) well he lives 15 minutes away and borrows mine... says because 90 in under powered for the broom... Dad bought non split shafts ...I was :headbang: dad you don't own a truck what you thinking.. he borrows mine.. so I might have to get another power head... :picard: he's my dad what ha gonna due!
    HDRock and eatonpcat like this.
  8. Canadian border VT
    oh I forgot to say mines about 6 years old and 2 stroke...
  9. Will C
    Will C
    New York
    I also got the 130 because I bought the unit originally with the rubber power sweep-that takes some power.
  10. HDRock
    Don't know about stihl but, I have a 31cc Ryobi that runs a cultivator , the cultivator wears me out , wouldn't want to do a big area with it, but like said , works gteat for removing tire ruts from lawn
    eatonpcat and Canadian border VT like this.
  11. mirnldi
    mirnldi
    Ct
    I have the 94 and it has some pretty good power. But I also have a yard boss with the cultivator attachment and wheel kit. The 94 kombi has more power than the yard boss
  12. Scotty Overkill
    I run the cultivator attachment with my KM56 powerhead quite often and it does just fine.
    XXL likes this.
  13. Marshel54
    Marshel54
    Pulled the trigger. KM 110 R. I got the power head, cultivator, brush cutter and a string trimmer attachment that mounts to the brush cutter head. Spent more than I would of liked, but it is only money. I did splurge and got the full shoulder harness. Off to play with it.
    HDRock, mirnldi, Will C and 2 others like this.
  14. mirnldi
    mirnldi
    Ct
    I will say the string trimmer is probably the best weed whacker I've ever used with the 94. I could imagine it being much better with the 110
  15. XXL
    XXL
    Ontario, Canada
    I didn't know Stihl made a 130 2-stroke. I thought it was only the 4-mix 4-stroke.
  16. Canadian border VT
    mine is split shaft kombi unit sorry no pics there were 3 sizes 90 110 and 130.. I tested the blade outside on brush it did what I wanted it might have been called a 250r but it's definitely 2 stroke 130
    XXL likes this.
