Stihl Fuel Line Replacement
Discussion in 'Chainsaws and Power Equipment' started by Woodchuck, Jan 25, 2015.
  1. Woodchuck
    Woodchuck
    Southeastern Ohio
    I suspect I have a fuel line leaking on the 036. I haven't identified the source of the leak yet but wondered if this something I should attempt? Your input is appreciated :)
  2. Cut4fun
    Cut4fun
    OHIO Redneck
    Easy to do. Have fun. Check other stuff too while in it.
    concretegrazer likes this.
  3. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Yupp, easy to do. I'd check/replace the fuel filter, too. You'll need:
    1. Hemostats or bent wire to grab the line from the tank
    2. Pliers/hemostats
    3. New fuel line (OEM is best, AM are ok)
    4. New fuel filter.
    Take air filter off...I usually do it with the carb off too to check/clean everything. Fuel line comes up through the tank housing via a small hole. It attaches directly to the carb and should be easy to remove/install. I always pull the lines out and cut 'em above the filter then slip them through the tank. I use a bit of mix to lube up the ends.
  4. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Need a manual?
  5. Woodchuck
    Woodchuck
    Southeastern Ohio
    Sounds simple enough, but never done this before. I'll take all the help I can get!
    Thanks for your original post...sometimes all it takes is someone that's been there before :thumbs:
  6. prell 73
    prell 73
    ia
    Easy to do did it on both my 170s just don't use a screwdriver on or u will poke a hole in it.
  7. Sam
    Sam
    Southern Minnesota
    I did the line on my 044. It was a bit of a PITA but totally DIY'able. The only way I could get it done on that saw was to remove the carb so besides getting the line through the tank hole hooking up the throttle lever was the next toughest part.
    prell 73 likes this.
  8. pantelis
    pantelis
    Europe
    Perfect . the operator have not identified if its a fuel line leak yet , and the service manuals are open
