Stihl Came Unglued, But Fixed, Then Came Unglued Again.
Discussion in 'Chainsaws and Power Equipment' started by JotulYokel, Oct 31, 2023.
  1. JotulYokel
    JotulYokel
    Missouri
    In 2019 I bought a new Stihl MS251 Wood Boss. I heat entirely with wood, and have a lot of oak on my place, as well as friends' places. I am frequently being offered large oak trees to take down. Right now I have 3 on my plate, that friends want me to fell. I'll take them down and process them for my stacks. Now I also have a spare MS251 that I bought new a few months ago. But this is about my original saw.
    So something happened to my original MS251 in Sept. I had not used it since the previous winter, and I had the air intake flap set to winter instead of summer. The saw overheated and died. I figured out what the problem was and flipped the flap, I let the saw cool down and it started up and ran just fine... for a few hours. But after a few hours of use it was unable to build power or speed. I took it to my buddy's saw shop. There are two little covers that are literally glued on to either side of the cylinder of the Stihl. When my saw over heated, it weakened the glue bond, and the cover loosened, which killed the power. My buddy said Stihl used to machine this part into the cylinder, but cheapened out and began glueing them on some years back. So my main saw was useless. He tried some JB Weld to glue it back in place, and that worked for a few hours, but the cover came unglued again.
    Here is a picture of the cover. There are two--one on either side of the saw.
    So my MS251 was useless. But I found a new Stihl engine on ebay for around $200 and it came today. So as soon as I install it, I'll have basically a new saw. For $200. I'll take that deal.
    The box says MS194 T, but the data tag on the new engine says MS 251
  2. Ohio dave
    Ohio dave
    Akron, OH
    It sucks that Stihl is cheaping out like that.
    You said big oaks with a 251? 251 is a fairly small homeowners saw. How big are these oaks?
  3. RCBS
    RCBS
    Over here
    Not cool Stihl. This reminds me of some oring issues that Husky had on their transfer covers some years back. The covers were fastened down, but the oring seals were deformed or improperly installed IIRC.
    PA Dan, Ronaldo, brenndatomu and 2 others like this.
  4. Barcroftb
    Barcroftb
    The Mitten
    Thought the same thing. Sounds like he should be looking for at least a 60cc saw given size of trees and frequency of use.
  5. buZZsaw BRAD
    Unfortunate that happened. If you are going to continue to cut larger wood another, higher CC saw maybe in your future. Perhaps a 311 or 391 in Stihls farm/ranch saws or a 59CC 362 in their pro model line. Not knocking the 251...a decent saw for what it is.
    I owned a 290 (in the farm/ranch level) for years and it served me well, but once i went to a pro model saw i never looked back. Very reliable and hold their resale value. Its also nice to have a choice of different sized saws for different sized wood.
    Ron T, brenndatomu and RCBS like this.
  6. The Wood Wolverine
    Glued on transfer covers, that's a new one on me. :loco: :crazy:
    brenndatomu, Jeffrey Svoboda and RCBS like this.
  7. buzz-saw
    buzz-saw
    Ct.
    Don't you know that the cost of screws due to supply chain issues have gone through the roof ?
    I can't believe that they would rely on some amazing stickie" stuff to hold engine parts together.
    Talk about a cheesie way out.
    Everyone is cutting corners wherever they can so be prepared to pay more and get less.
  8. RCBS
    RCBS
    Over here
    Noticed the bold about 10 years ago honestly. The money I earn is worth less, and the products that it buys are of lesser quality.
  9. JotulYokel
    JotulYokel
    Missouri
    I'm 76, and need a lighter saw. I take my time and try not to overload the saw. The present oak I'm working on has 130 growth rings and is 20-22 inches in diameter 4 feet above the ground.
  10. Scotty Overkill
    I'd recommend stepping up to a professional grade saw in the 60-80cc class if you're felling wood. Lots of great deals out there if you look. A 034/044-440, 046-460 would suit your needs and then some. And you won't have glued pieces felling off either. And they're much more fun to run!
  11. Eggshooterist
    Eggshooterist
    Erff
    I believe its not a new process gluing the covers on. Even some of the professional saws have this too I believe. The 201 comes to mind.
    brenndatomu likes this.
  12. Eggshooterist
    Eggshooterist
    Erff
    I have never had to use the winter shutter position on any saw and I'm in Michigan.
    Ron T and brenndatomu like this.
  13. MasterMech
    I doubt that's what killed the saw. Those flaps don't affect the actual cooling of the saw, just allows some warm air from the engine cooling stream to enter the carburetor airbox. These are only useful if you are experiencing carburetor icing. Carb icing only happens within a limited window of temperature and relative humidity conditions. The worst that would happen with it in "winter" position all the time is that it would allow extra debris in the airbox and perhaps reduce ultimate power a bit due to the higher air inlet temps.
    Still unacceptable that the covers came loose on their own. I get it, not casting bosses and machining for fasteners on each cylinder is probably a significant savings on the manufacturing side. But this is a failure of OEM materials and/or workmanship. Even if outside the warranty period - A diligent dealer service manager should be able to get it covered.
  14. buzz-saw
    buzz-saw
    Ct.
    Yeah, it started a while back but all the covid BS seems to have sent it into a tail-spin.
    I had a saying in the shop one day and it has kind of stuck ; " Prepare to be Disappointed".
    It isn't far from the truth.
  15. MasterMech
    Each dollar you earn is certainly worth less, year over year. But I'd argue that the quality of the products we buy has gone in the opposite direction.
    A Homelite XL-12 was roughly $350 before they stopped manufacturing them in the 1980s. Adjusted for inflation, that's over $1,000 today. Would you give $1,000 for a new-in-box Homelite XL-12 today? I didn't think so. :emptywallet:
    Consider the MS250. It's one of few saws you can still go buy that's largely unchanged from the original design introduced 30 flippin' years ago. :eek: As a $400 saw today, that design has been in production since the early 1990s (as the 025). I don't remember the price since I didn't start selling them until about 2003 or so, but I think it was introduced at around $250. Anything more than that will just further prove my point. Speaking of - That's $800+ today. So, we're selling the SAME saw, built from the SAME materials, and carrying the SAME support (or possibly better) for half the original cost, adjusted for inflation.
    There's a lot of junk out there for sure. But in general, we are making better products for the same cost compared to 30+ years ago. What is a $200 saw today, the Stihl MS170? How much chainsaw could you buy for $85 in 1990? :sherlock:
    Now - if we wanna talk about pickups, $20k bought you a pretty nicely optioned (new) 4x4 1/2 ton extended cab with a V8 in 1993. That's about $42k today. What kind of pickup can you go buy for $42k today?
    EDIT: A new Silverado double cab with a 5.3 V8 (probably not my first choice of engine but I digress) in WT trim, not Custom or LT, is $47k MSRP.
    Skier76, JD Guy, Horkn and 7 others like this.
  16. brenndatomu
  17. MasterMech
    I'd honestly be curious if anybody had a receipt or knew for sure what a cheap saw would have cost in that time. Anybody remember what the Mini-Macs sold for new? LOL
  18. Lehman
    Lehman
    Minnesota
    Actually that’s how they’ve been built since this saw model came out on the older ones, 271/291, 311/391 is the same way. The newer updated versions are different if I remember right. The cylinders are easier to make with transfer covers.
    Horkn and Eggshooterist like this.
  19. Lehman
    Lehman
    Minnesota
    new version has solid transfers no covers, the 271/291, 311/391 were updated also. The cheaper ones are usually the old style.
    Eggshooterist and brenndatomu like this.
  20. Lehman
    Lehman
    Minnesota
    Your best bet is to buy a ms 261 next, full on pro saw with removeable cylinder. This will also weigh about the same as a ms 251 but have way more power even stock. Ms 271 is kind of the homeowner version of the 261 but less power and heavier. If you buy a 261 it will probably be the last you have to buy.
