Stihl 064 oil pump questions
Discussion in 'Chainsaws and Power Equipment' started by NewToStihl, Dec 17, 2014.
  1. NewToStihl
    NewToStihl
    Central Indiana
    It looks as though over time there were two different OE oil pumps on the Stihl 064. The early version is NLA and I can't seem to find any information on it (specifically, the stroke/output). I have an 066 Red Light that I'm running a 32" bar on and when cutting large fairly dry wood it's not putting out enough oil. I ordered the higher output control bolt and pump piston for it (just a few days before mdavlee's post about modding the parts for more output!).
    I'm looking to possibly put a 36" on the 066 after the pump upgrade and then put the 32" on an 064. There seems to be a ton of information out there about oilers and abilities, but I can't find what I need. So, here are my questions:
    1. Is there an output difference between the early 064 oil pump and the late one?
    2. mediaCAT doesn't show anything related to an HO oil pump or parts for the 064 - do they exist?
    3. I know the early & late oil pumps look different, but if there is a HO version of one of the oil pumps for the 064 is there a way to visibly identify it or tell it apart from a standard one?
    Thanks!
  2. mdavlee
    mdavlee
    The early oilers won't interchange with the layer ones. I don't know the cut off for that. Those you can mod and get plenty of output. Maybe this will help a few others if they have 064s.
