Stihl 009L VERY Hard Pulling to Start
Discussion in 'Chainsaws and Power Equipment' started by Dumf, Mar 2, 2020.
  1. Dumf
    Dumf Banned
    Maine
    My tree and trail saw, a Stihl 009 has become almost impossible to pull. Ran perfectly until a month ago.
    And yes, according to the chainsaw dealer and Bruno the logger ( no longer a friend :confused: ) " I'm pulling weak".
    Here's what's been done with not much success:
    1.Rope and pulley mechanism are fine. Pulls easy without the plug in.
    2. The muffler and screen were cleaned.
    3. Poured acetone into the carb, shook it around, then emptied the carb.
    4. Plug is clean and gaped correct with spark.
    5. Pulled apart the saw and thoroughly cleaned out years of oiled sawdust.
    6. The choke mechanism works fine.
    Finally--poured some mix into the cylinder (plug hole ) , swished it around for a few minutes and it pulled easy and started...once.
    Suggestions ? Explanations ?
    I really like this top handled saw for what it can do. Discontinued by Stihl.:(
  2. Dumf
    Dumf Banned
    Maine
    Hey, where are all the experts ? :binoculars:
    Needing some help here ! :headbang::headbang:
    HEEELLLLPPPP
    T.Jeff Veal and Screwloose like this.
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Maybe in bed?
    Screwloose and Dumf like this.
  4. Dumf
    Dumf Banned
    Maine
    It's only zero dark hundred on the left coast.
    Everyone else: IT IS TIME.:faint:
    Screwloose likes this.
  5. buzz-saw
    buzz-saw
    Ct.
    Did you or are you able to look at the piston through the exhaust to check for scoring ?
  6. Dumf
    Dumf Banned
    Maine
    Yup, but looks fine for what is visible.
    The "inconvenient truth" ( thanks Al ) is that I'm not sure what to look for as "scoring".:emb:
  7. Nixon
    Nixon
    West Sunbury,Pa .
    This is a WAG . But, Can you look at the upper part of the combustion chamber . There could be a build up of carbon there . Maybe causing a rise in compression ,and resistance to being pulled over ?
  8. Dumf
    Dumf Banned
    Maine
    Et voilà ... encore une fois
    TLA..."WAG". :faint:
  9. clemsonfor
    Make sure that flywheel isn't hitting anything.....like the coil.
    Make sure chain brake is free.
    Sent from my moto g(7) using Tapatalk
    M2theB, T.Jeff Veal and Screwloose like this.
  10. Warner
    Warner
    Eat some wheaties before you head out in the am?
  11. Screwloose
    Screwloose
    Quit pouring stuff in the carb. Is this the brake fluid saw ?
  12. buzz-saw
    buzz-saw
    Ct.
    ??? Brake fluid and rubber can be a bad combination. It swells rubber.
    You know the old trick for things like a leaking power steering pump seal = add some brake fluid and it swells the seal and stops the leak.
    If it is the brake fluid saw ( and I don't know this ) maybe a swollen crank seal or two ?
    M2theB, brenndatomu and Screwloose like this.
  13. Marshel54
    Marshel54
    My MS250 did the same thing around a year ago. It was all I could do to pull it through the compression cycle.
    I did like you and pulled the plug. Pulled a few times with the the plug out. Pulled fine. Put the plug back in and it started as normal. Been running fine ever since.
    What was a wrong beyond me. The only thing I could figure out is it hadn't been started in 4 months. Could the cylinder been dry out?
  14. The Wood Wolverine
    Wasn't too long ago I had an 011av on my bench. Very pesky little buggers to work on.
    These are carbon streaks. If you have an overly excessive build up of carbon, it could increase compression, though I doubt to the point you have a hard time pulling the saw over.
    Here's scoring:
    If you can't keep her running, I'd ask when the last time was that you changed fuel lines and rebuilt the carb with new diaphragms?
    Dumf, brenndatomu and Screwloose like this.
  15. Nixon
    Nixon
    West Sunbury,Pa .
    Wild _ssed Guess .
  16. M2theB
    M2theB
    Central Massachusetts
    Pull the plug and then pull it over. What’s that like?
  17. Dumf
    Dumf Banned
    Maine
    Fine pics....thx.:salute: Are those the "scorings" to find ?
    Never rebuilt this carb or changed fuel lines.
    Due to ham hands and sticky fingers as well as a lost brain that forgets where things "go" I will never again rebuild a carb. Never.:headbang:
    You got to know what you can't do well ( and, know what you can do ).
    P.S. "Pulls easy without the plug in " from O.P.
  18. brenndatomu
    I remember reading about another Stihl...larger, don't recall the exact model, that was acting the same, ended up being something wrong with the recoil starter...don't know that I ever heard what the exact problem was...might be something to look at though.
  19. Dumf
    Dumf Banned
    Maine
    Recoil starter mechanism is fine. Pulls and retracts easy and normal with the plug out.
    The rope rewinds correctly.
    The 009 is small and barky enough so that it can easily backpacked, climbed, and used to get into a mess of blowdowns so that I can get to the trunk with the 261.
    Thx.
  20. The Wood Wolverine
    Maybe it's time for a small saw like that with a decomp plug to assist you in starting it. I didn't have the 011 apart enough to know if one could be added. Some saws that is possible.
