STICKING IT TO THE POWER MAN.
Discussion in 'The Wood Pile' started by CHeath, Mar 1, 2017.
  1. CHeath
    CHeath
    NWNC Mountains
    Alright guys, I've not been here too long but I came from a similar type forum so I am well seasoned as they say. Well, I wont be burning again until November. I had a heat pump installed and have have been using it but its just not the same plus to warm all the female feet in my home, it takes a lot and you really have to keep the thermostat turned up and the power man loves it. So, with that being said, I wanted to take a day or so at the first of this year and really REALLY pay attention to where I could save money. Man, I found a lot of places that needed improvement and with some help of google and some other forum friends, I have came a LONG way on saving some money that was literally going through the cracks of my walls, floors and windows. Alright here is a snippet..... I called to try to get a blower door test done but there were none near me and I was going to have to pay a hefty fee for the drive so I utilized mt local Duke Power but they wont be here until the end of March.
    So, even before duke gets here, I took it upon myself. My house is brick, 2100 sq ft, large great room in the center and a full unfinished basement and 9 foot ceilings.It is tough to heat. Its also 39 years old with original windows. So here are some of the things I have done so take these down and if you want , I certainly recommend you give it a shot.
    Some of these were done up to a year ago but most were done in this year so far. Can you tell I was tired of freezing and pay high power? lol
    Last Year
    Installed new Trane XR15 3.5 ton outdoor unit and new Trane indoor unit
    R-30 cellulose in the attic
    2017
    Foam Wrapped the cold and hot water lines in the basement.
    Foam wrapped and taped water heater lines
    Insulated trunk of unit and cold air return
    insulated water heater.
    Foil taped all seams in the register lines
    Sealed where register meet the floor
    Insulated all large holes in basement ceiling (large pipe holes, shower drains etc.)
    Put new door sweeps on basement double doors
    New Foam on basement double doors
    Found that the only 2 basement windows we have were partially open on top and bottom
    New Foam around main door entrance
    Rubber insulation around window slide tracks
    covered up doggy door (she died)
    sealed off fireplace
    sheet metal over chimney caps and silo-coned them shut
    Replaced every bulb in the house with LED
    Installed smart power strips in every room with phantom appliances
    Put all DVR's on timers to only run 8 am until Midnight then shut off completely from midnight to 8 am
    Put timers on both freezers to hold at 0 degrees instead of the lowest setting of minus 5 degrees
    Cleaned the coils on the refrigerator with shop vac and scrub brush
    Put in a new trane smart Thermostat
    Insulated every light switch and outlet with insulated pads
    Hand Washed dishes all but 2 days in Feb ( I had the flu so screw it, we let the dishwasher do it)
    Most importantly, had a family meeting about being intentional with not only our money but our resources. Making a smaller footprint on Mother Earth and keeping more money in our pockets at bill time. This went VERY well. There are THREE teenagers and my wife in my house and though, I never said anything before, some days, I would count 7 or 8 showers between us all. They have really taken control and by doing this, I think it will carryover to their homes and lives when they move out. We are also on a tight budget and the kids are very aware of this as well and it shows when they go shopping. Overall and I am very proud of them so far. Plus our water usage dropped from a 5500 gallon average per month to a 3500 gallon average per month. Water bill went from $60 to $45
    Did I spent a lot of money? Yes. Where some of these useless? Probably. Does it matter? No to me because I wanted to do it and it got done. Was February a mild month? yes. It was also short. I do take this into consideration. Is march going to be higher? Probably.
    For the last 3 years (as far as Duke Energy will let me go back). I have averaged 1800 kw/h per month usage averaging $200 or more per month ( I know, I am ashamed, we are hogs but not anymore) with the largest month being 2400 kw/h. We have never been under 1000 kw/h but once in 2013 when I was wood burning it was 1100.
    Feb 2017 was 1148 kw/h and our bill was $108. With all that time and money spent, I still feel like the heavy weight champion of the world.
    Thanks again to ALL that contributed ideas and thoughts. ITS NOT OVER tho! still plenty of more to do. I do want to mastic the ducts and seal off a little more things here and there and when my 20 year old electric water heaters dies, go with a heat pump water heater as well as the 20 year old fridge even tho it takes nothing hardly to run
    Thanks again guys!
  2. Woodchuck Chuck
    Woodchuck Chuck
    Auckland, New Zealand.
    Massive effort mate, especially with the people involved. That's often the hardest work but it sounds like you've got them helping out too. We'll done.
  3. stuckinthemuck
    stuckinthemuck
    Wow!! 2400 Kw/h where I live would be $456. I think if I had that bill I would cut my electrical supply line with a set of loppers.
  4. Jon_E
    Jon_E
    Southwestern Vermont
    Yeah I'm averaging 1200 kWh and paying just over $200 a month. Looks like you're on a roll.
  5. CHeath
    CHeath
    NWNC Mountains
    My cost per kw/h is .09 but fees and tax makes it a bit more. They are not that bad based on what Ive heard on here for power. Some of these guys are getting the business. lol
  6. stuckinthemuck
    stuckinthemuck
  7. papadave
    First things first......Welcome aboard, CHeath .
    You've done some good work so far.
    Here's a very good site with tons of info on how to cut your energy footprint.
    I think I'd strangle myself if my elec. usage was more than 500Kwh/month.
    During the summer, it usually runs about 350, although I've gotten as low as about 270 in this 1240 sq ft house. When the oldest daughter and Gkids lived with us........well, you don't have to imagine what that did to the utility use.
    BuildItSolar: Solar energy projects for Do It Yourselfers to save money and reduce pollution
  8. Spencer
    Spencer
    Indiana
    we used 492 kwh last month. cost is 14c/kwh here. Gas for the water heater, electric for everything else, wood for heat.
  9. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    With a thread title like that we may start to get a whole new type of crowd here! :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    Seriously though, welcome aboard! :thumbs:
  10. tigeroak
    tigeroak
    kansas illinois
    Wife read some where that the led bulbs will only last around 5 years in standard light fixtures. You have to replace all your light fixtures to led too. At a cost of around 80-90.00 each. Now You said you put r-30 in attic- we have r-79 in mine[ 2 -30 and a 19]. Walls are r-20 floors are r-24 , all new windows and doors. Make sure your lights are off if not in the room. Try this and we did go the whole day WITHOUT turning a light , shower, tv, no phones nothing on for one day. Keep freezers and such going but nothing else no cooking with gas-microwave and so on. Wood stove is ok or outside with wood no gas grill. Do this once a month. We liked it and did it for several years.
  11. Farmboy707
    Farmboy707
    Southern Ontario
    I'd give my right arm for that kinda bill!!! Last month 550kw/h $160 curse you Kathleen Wynne!!!!:headbang:
  12. Backwoods Savage
    CHeath you've done one swell job and will now enjoy the benefits.
    For you other guys, eat our heart out. We just received our electric bill for February. Usage was 185 kwh for a total cost of $32.75 or $1.13 per day. Yes, our water heater is LP and so is the cooking stove. Most of the lights are still the old style lights. Refrigerator (big) about 15 years old. Two freezers are both well over 20 years old.
  13. stuckinthemuck
    stuckinthemuck
  14. CHeath
    CHeath
    NWNC Mountains
    Thanks, I am a huge fan of the build it solar site. This is on the wish list. I have the roof room (with a wood shed aimed south) that will hold a 9kw system. This would run $40k but if my state brings back the 35% credit and the feds keep the current 30% credit, I will sign up.
  15. papadave
    Reduce use as much as possible first. The need for elec. goes down, then so does the size of the array. With your family on board, it's entirely possible to reduce even more.
    A 9000 Kw system is quite large. Your house sounds to have been built a couple years after ours, when the concern for insulation, air sealing and all those things weren't that important.
    This has been discussed before, so bear with me.......we have elec. dryer, elec. stove, nat. gas WH, well pump. I have my laptop on a power strip which gets turned off every night. Started doing the same with the modem, and would like to do the DTV receiver, but that might mess up the guide updates.......don't know.
    Haven't been able to get my wife completely on board, so it's up to me to do what I can.
    On the flip side, I've been burning a bit more nat. gas this winter, since I'm keeping the shop slightly heated, and now have the house furnace functional again ( hardly used though).
  16. Farmboy707
    Farmboy707
    Southern Ontario
  17. stuckinthemuck
    stuckinthemuck
    That's interesting. I'm pretty sure we don't have that where I am and just pay for what we use. I pay $0.19 USD for generation and delivery. So I think that works out to over 40% more than you pay with the exchange rate accounted for. Of course that doesn't factor in paying for power that I'm not using so it's apples and oranges until we know that. Criminals. All of 'em.
  18. Farmboy707
    Farmboy707
    Southern Ontario
    What's your state tax?
    Blazing and CHeath like this.
  19. stuckinthemuck
    stuckinthemuck
    $0.00055/KwH consumption tax. $0.34 on my latest bill. Yours?
    Backwoods Savage and Blazing like this.
  20. CHeath
    CHeath
    NWNC Mountains
    yep, doing everything we can. Just being intentional is key. Everyone is on board but my 12 year old daughter lol. Its her world, we just live in it you know? lol
