St Croix Hastings tube scraper rod broke
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by BHags, Aug 30, 2017.
  1. BHags
    BHags
    Massachusetts
    The Tube Scraper Rod has broken off from the Heat Exchange Tube Scraper on my Hastings stove. I can't see how I can replace them. The scraper is used daily to remove ash buildup on the tubes carrying the hot air into the room. Any ideas?
  2. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Post a piccy of the area the rod broke off and how the rod exits the stove and we can likely come up with a fix
    CleanFire, ivanhoe, BHags and 3 others like this.
  3. don2222
    don2222
    Salem NH
    Hello
    I fixed one just like it on a St Croix Greenfield. What usually happens is the weld breaks on the piece that holds the rod to the rake. The new rod from St Croix is threaded at the end so it can be fastened to the rake with a nut.
    So you have to get the old rod out and the only way to do that is to cut the old rod out with a Dremel. Be careful not to cut into the heat exchanger tubes.
    That is the way!
    Hope that helps. :)
  4. wildwest
    Wyoming high plains
  5. slvrblkk
    slvrblkk
    Northampton, PA
    If you can get a die on the end or the rod and cut some threads on it. Drill a hole through the scraper on the tubes and put a couple nuts on it.
    CleanFire, eatonpcat, ivanhoe and 3 others like this.
  6. BHags
    BHags
    Massachusetts
    Looks like the way to go. The whole thing could not be in a less convenient place, I'm getting to old to be bending like that! Thanks for the input guys!
    CleanFire, ivanhoe, wildwest and 2 others like this.
  7. IHATEPROPANE
    IHATEPROPANE
  8. slvrblkk
    slvrblkk
    Northampton, PA
    duct tape :D
    CleanFire, ivanhoe, jtakeman and 3 others like this.
  9. IHATEPROPANE
    IHATEPROPANE
  10. imacman
    imacman
    Denver, NC
    HEY! I resemble that remark! :wacky:
  11. don2222
    don2222
    Salem NH
    When I say go Point to the right!
    CleanFire, wildwest and IHATEPROPANE like this.
  12. BHags
    BHags
    Massachusetts
    So instead of cutting inside with the chance of cutting into an air tube, I pulled the rod out, then just cut it in half with a hacksaw, and pulled it out from inside. No chance of destroying the stove!
    CleanFire, ivanhoe, wildwest and 4 others like this.
  13. bogieb
    Good thinking!
  14. BHags
    BHags
    Massachusetts
    So after lighting the stove a couple times, I kept smelling ash getting into the room. I checked gaskets, snugged up bolts, checked the pipe. I think I found it. The replacement scraper rod is a little thinner than the old one, leaving a gap where it goes into the stove, right where the room air blows out. For now, I wrapped foil tape around the rod where it makes contact to the stove when it is pushed all the way in. I think that helped. Any ideas?
  15. jtakeman
    I picked up a clamp collar and slide it over the rod. Seems to work and rod still functions as normal.
    DAYTON Shaft Collars - Couplings, Collars, and Adapters - Grainger Industrial Supply
    CleanFire, ivanhoe, BHags and 2 others like this.
  16. eatonpcat
    Hmmmm!!!
  17. slvrblkk
    slvrblkk
    Northampton, PA
    :whistle:
    CleanFire, imacman and eatonpcat like this.
  18. krooser
    krooser
    Waupaca, WI
    Remove the frbagistat and weld an intermediary protrusion onto the dereclaimer and hope for the best... last time my dehumdistat reluctor stopped working and I was forced to redeliver the uptonforwrench in the secondary ditzeliminator.
    Should still be under the lifetime unlimited warranty.
  19. CleanFire
    CleanFire
    ^^ I understood that! :rofl: :lol::rofl: :lol::rofl: :lol:
    BHags, imacman and jtakeman like this.
  20. jtakeman
    o_O
    BHags, imacman and CleanFire like this.
