Splitting wood green or dry by species??
Discussion in 'The Wood Pile' started by Dakota Hoarder, Aug 10, 2020.
  1. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Does anybody find certain species of wood to be easier to split either green or dry?
    I typically like to split wood as soon as it’s cut for 2 reasons. 1 so I only have to stack it one time and 2 so it can start to dry ASAP.
    I find maple, ash, and walnut split about the same green or dry.
    Mulberry splits better dry
    Box Elder splits better green and is a PIA! To try to split green
    Elm doesn’t split.
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I split a lot of elm dry. Standing dead elm is my staple wood. If & when I get it live or green I’ll buck it into rounds and split it in a year or two. The bark will fall right off then too. Not a lot of experience with other woods. But green hackberry is kinda a pain to split. Standing dead ash is nice when I can get it.
    Chaz, JoeinO, Mag Craft and 10 others like this.
  3. Midwinter
    Easier to split when green: apple, black locust, yellow birch, red maple, cedar, cherry.
    Easier to split when dried for awhile: red oak, pine.
    Just my opinion.
    Chaz, Sourwood, JoeinO and 12 others like this.
  4. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    It has been my experience that Ash splits easier when green.
    Irishman29, Chaz, JoeinO and 10 others like this.
  5. Loon
    Loon
    North of the border
    'Elm doesn’t split'
    Have 3 very large dead Elms on the property and they are still standing for this reason Dakota.:whistle: :cheers:
  6. Backwoods Savage
    Contrary to the "elm don't split" crowd, I'm a bit like Sandhillbilly. The difference is I wait until the tree is not only dead but the bark is almost all off before cutting. The wood is hard then and most times if you need it the top half or 2/3 of the tree will be ready to burn right after cutting. In addition,lots of that elm can even be split by hand. It is a great burning firewood.
    Chaz, JDU, JoeinO and 13 others like this.
  7. Jack Straw
    Jack Straw
    That’s the only way to go with Elm! Great advice
    Chaz, JoeinO, T.Jeff Veal and 7 others like this.
  8. Jack Straw
    Jack Straw
    It’s the exact opposite for White Birtch! You want to cut it down when it starts looking sick! You want to buck and split it the very next day. The third day stack it and maybe it will be ok!
  9. Sandhillbilly
    Sandhillbilly
    Exactly :yes:
  10. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Cant speak on splitting black locust when its green, as mine has been mostly barkless and down for a while, or standing dead. Splits easy for me. Sounds like bowling pins falling.
  11. fox9988
    fox9988
    NW Arkansas 72717
    Sycamore spilts much easier dried.
    Deererainman, Timberdog, Chaz and 8 others like this.
  12. Rich L
    Rich L
    Eastern Mass.
    Elm splits best when it's really cold and has been sitting in the cold for awhile.
    Ryence, Chaz, Chazsbetterhalf and 7 others like this.
  13. Eric Wanderweg
    I noticed apple splits much better the greener it is. I cut one down back in early April and split most of it by hand within a couple days. Not the easiest splitting stuff, lots of crotches/limbs etc. but I got through it. I decided to have a go at it a couple weeks ago with the remaining rounds. Totally different animal. I'm convinced that over the summer, granite gremlins from New Hampshire have slowly been changing the cell structure of the wood while I sleep. They were probably laughing at me through the trees as I struck blow after blow until I gave up and left it alone. The heat didn't help I'm sure. I have a splitter coming this week so I'll let the hydraulics have the final say, probably in the cooler weather.
  14. Sandhillbilly
    Sandhillbilly
    In December through probably February I took out a BUNCH of living cottonwoods. See my “if it was anything but cottonwood” post. I saved a pretty good size pile of logs. In March I bucked a bunch of it into rounds and stacked them. Last weekend I took home a dozen to split. The ends are very checked and most of the bark falls right off as soon as the splitter hits it. But it’s still plenty wet and stringy inside. I’ll probably get some more split up when it starts cooling off in a month or so. But I think I’ll wait until it freezes to do most of it
    Chaz, Chazsbetterhalf, JoeinO and 7 others like this.
  15. sirbuildalot
    sirbuildalot
    Mass
    You fought the good fight. Sometimes you break the wood, sometimes the wood breaks you!!!
  16. Eric Wanderweg
    Yep, try as I might I wasn't able to pop those gnarly pieces open. That's some dense, heavy wood that I'm hoping will provide some good heat. I'm definitely looking forward to getting my splitter though; I've got a growing pile of knotty blue spruce and a mountain of 30" red oak rounds I'm going to run through it first.
    Chaz, Chazsbetterhalf, JoeinO and 5 others like this.
  17. sirbuildalot
    sirbuildalot
    Mass
    What brand and model splitter are you getting?
  18. metalcuttr
    metalcuttr
    western WA
    One wood that, when dry, I would not even attempt without a hydraulic splitter. That is Madrone. The gnarlies are horrible even green. Larger Fir butts seem to split easier after a couple months curing imo.
  19. Eric Wanderweg
    County Line 25 ton from TSC
  20. Cash Larue
    Cash Larue
    Pine, CO
    I completely agree. I wait until the bark is falling off before I split elm. I’ve never had any trouble with it when I do that. Burns great too.
    Side note: Cottonwood splits relatively easy when green. But is like splitting reinforced concrete when dry.
