Splitting some small logs- quick, fast, in a hurry!
Discussion in 'The Wood Pile' started by Steve33, Sep 12, 2020.
  1. Steve33
    Steve33
    PA
    Hand splitting made easy!
  2. buZZsaw BRAD
    Ive seen the tire method used before and have never tried it. Eventually ill set one up. Must make quick work of them! :axe:
  3. amateur cutter
    It really does help to speed things up. Everything stays in place & you just whack away. Cuts time by about 1/3 I would guess.
  4. buZZsaw BRAD
    My problem is that i could be splitting in a number of locations.
    Eventually ill catch on to "easier" is better. :picard:
  5. amateur cutter
    Throw an old tire in your truck. I like 16" tires for the bigger diameter.
  6. buZZsaw BRAD
    Is one tire sufficient or should i stack two? Can it be directly on the ground?
