Splitter motor ?
Discussion in 'Chainsaws and Power Equipment' started by B.Brown, Apr 6, 2021.
  1. B.Brown
    B.Brown
    USA
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg A guy I know brought this motor over its a power washer motor. The pump is bad the tag says so, supposedly it runs good. I've got a 22 ton splitter, that is a vertical shaft splitter, but my motor needs replaced. What do you all think about trading out the power washer motor for my motor. Pros, cons you guys give me your opinion, please. Here are some pics of the power washer motor
    Horkn, amateur cutter and mat60 like this.
  2. huskihl
    huskihl
    Looks like a Honda clone, maybe Predator 6.5 hp. Did you remove the air filter or was it brought to you like that? If it won’t start, check the oil. If it still won’t start, the low oil sending unit is possibly the cause. Unplug the yellow wires by the kill switch and try it
    T.Jeff Veal, Horkn and amateur cutter like this.
  3. B.Brown
    B.Brown
    USA
    It was brought too me with the air filter removed it was cracked but, had the foam filter in the housing. , the guy who gave it to the guy i know, said, the motor runs.
  4. huskihl
    huskihl
    Never owned one myself, but I’ve heard good reviews on the Predator. If I had a wood splitter in need of a motor I wouldn’t hesitate to use one
  5. B.Brown
    B.Brown
    USA
    Here's some GOOD NEWS, the guy who the Pwasher was given to, just brought it back by my place, choked it, pulled it though one time, and it fired right up:yes: runs like a cat, nice and smooth, quiet as all get out. Gettin excited about this motor!! :thumbs:
  6. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Going from vertical to horizontal will require a bit of effort. But If’n you’re kinda handy and have some equipment ( welder, drill press, torch, etc.) its definitely doable
  7. buzz-saw
    buzz-saw
    Ct.
    Switching over is going to be a fair amount of work.
    For the time and effort you are going to have to put into it you might want to think about just getting a replacement engine.
    Harbor freight does make a vertical shaft preditor motor. For the price they are hard to beat.[​IMG]
  8. triptester
    triptester
    S.E.Wisc.
    That motor will most likely have a tapered shaft, typical for power washers and generators, this requires machining the shaft to adapt to a hydraulic pump.
  9. buzz-saw
    buzz-saw
    Ct.
    My old splitter was a vertical shaft B&Stratton , it had a straight shaft with a standard Love-Joy coupler and the pump bolted directly to the base that the motor mounts on top of. This is what the Predator shows for a shaft. Worst case you might need a different coupler on the motor side depending on original shaft size.
    You can purchase just one half if it is a Love-Joy.
    Keyway
    3/16 in.
    Shaft length (in.)
    3.2 in. / 80.2 mm
    Shaft Diameter
    7/8 in. (22.2mm)
    Currently shows at $159.00
  10. amateur cutter
    I personally wouldn't screw around going from vertical to horizontal configuration. For the couple hundred dollars that the direct fit motor costs I'd just bolt a new one & go.
    T.Jeff Veal, Horkn and huskihl like this.
  11. Eric VW
    Why not replace the pump and have you a nice pressure washer B.Brown? Keep or sell it at that point.
  12. Horkn
    Clone of a clone. While it may not say predator on it, there's lots of congress out there.
    I have a predator on my old didier splitter. Best $100 spent ever.
    You'd need to check the output shaft to see if it is the same size as what you have in the splitter. You might get lucky, or you might need to buy some lovejoy coupler parts, but it can be made to work, even if the shaft sizes are different.
    Edit, I see your splitter needs a vertical shaft. That will make more work
  13. Fifelaker
    Fifelaker
    Fife Lake Mi.
    You will need something like this. When my B&S dies it will get a horizontal shaft Honda clone of some sort. I dont care for the pump hanging down the way it does.
    T.Jeff Veal likes this.
