Splitter Bolt
Discussion in 'Chainsaws and Power Equipment' started by ReelFaster, Feb 24, 2025 at 10:28 AM.
  1. ReelFaster
    ReelFaster
    S.Jersey
    Hey gang, trying to locate and find a bolt that secures this gas tank to the splitter. Not really sure of the terminology so my searches are wild in results. It's a powertek brand and their website is crap for parts unless I am missing something.
    Long story short, I borrow the splitter from time to time from my brother in law. Was using it before winter set in and noticed the gas tank vibrating immensely. Closer inspection revealed a few of the bolts were missing and only one remained.
    Someone else had it before me and came to me this way as I checked my property like crazy for the missing bolts. I am sure I can rig it with another bolt but its kind of tricky with that neck portion that fits into a plastic opening on the lower part of the tank making it secure. Using a regular bolt of same size (M6-1.00x16) Finding exact match would be the best bet. Thanks in advance!
    MikeInMa and T.Jeff Veal like this.
  2. Woodtroll
    Woodtroll
    Mtns of SW VA
    That’s called a shoulder bolt, made so that the threads can tighten and hold (usually!) while the smooth shoulder acts as a spacer so the plastic it passes through isn’t crushed.
    If you can’t find bolts of correct dimensions easily, you can make do with a regular bolt of the correct length and thread, and washers under the head over tubing cut to the same length as the shoulder on the original bolt, so that it serves the same purpose as the shoulder. Good hardware stores (not Lowe’s or Home Depot) usually have a good selection of stainless steel or brass tubing. Hobby shops often do, too.
    Good luck!
    MikeInMa and RCBS like this.
  3. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Now that you know it’s called a shoulder bolt, plug in the specs into your search. Should probably get plenty of hits.
    MikeInMa and The Wood Wolverine like this.
