Speeco 4 Way Wedge
Discussion in 'Chainsaws and Power Equipment' started by Carbine, Oct 7, 2015.
  1. Carbine
    Carbine
    Anyone using one of these rascals? Thinking about getting one...
    eBay
    I expect that I'll prob have to do a little fab work to it, but thought on the ash rounds it would speed things up.
    Brad38 and Eric VW like this.
  2. Woodrat1276
    Woodrat1276
    Ky
    I have not but it me interested in one myself. However the reviews I read aren't very good though.
    Curious to see what others here have to say about them too
  3. Grizzly Adam
    Grizzly Adam Guest
    I also have a passing fancy but I doubt I would use it.
  4. Well Seasoned
    Curious here too, however watch the gnarly twisted pieces. A 4 way will not allow the split to turn as oppossed to a single wedge from what I have read, possibly creating a cylinder problem
    papadave likes this.
  5. papadave
    For use with soft wood only
    Carbine and Well Seasoned like this.
  6. lukem
    Would probably be fine in straight grained hardwood. Pine can be pretty snarly...I'd rather split red oak over pine any day.
    papadave and Well Seasoned like this.
  7. papadave
    Just quoting from further down the page, but I agree......Pine can be the devil.
    Carbine and WVhunter like this.
  8. WVhunter
    WVhunter
    Mountains of WV
    I have one and really like it. I have split some big twisted pieces of Hickory and Oak. I split some 24" to 28" rounds with it and no problems. I split the rounds once with the 4 way and some I split again using the 4 way. I have also used it to split the rounds once then take it off and split it smaller with the single wedge. I am very pleased over all with it, 95% of what I split is Hardwood.
    HDRock, Jack Straw and papadave like this.
  9. papadave
    Good to know.
    I bet they're just trying to cover their butt with that little disclaimer. It looks pretty beefy.
    If I had one, I doubt I'd change it out while splitting hardwood.
    WVhunter likes this.
  10. WVhunter
    WVhunter
    Mountains of WV
    Easy to change Dave, it just slides over top of the regular wedge, slide it on, slide it off, 2 seconds your done.... :yes:
  11. SquareFile
    SquareFile
    somewhere
    From my experience of making my own slip on 4 way wedge I can't visualize that one being effective on various types of wood. The side wedges are short and the leading wedge would already be be seperating the split further away. Also they would act as a knife and not a wedge to pop the split. Just my .02
    Carbine likes this.
  12. Carbine
    Carbine
    Good look on that Shawn, I see what you are saying.
  13. SquareFile
    SquareFile
    somewhere
    The one I made the side wedges make contact first. The main wedge become the secondary split. The log don't have a choice to go thru it. Hickory is the only wood I take it off. The 5" bore cylinder struggles splitting it four ways.
    Carbine likes this.
  14. fordf150
    fordf150
    Newcomerstown ,Ohio
    they work good but require some fab work. the strap that goes over the back bends easily. fastleo has one for his splitter. first outing and we had the back strap bent and had to fab a new one. we used 1" thick steel to make a new strap that hooks over the back of the wedge and extended the strap clear out to the front of the wedge so we gained an 2 inches of wedge height in the process. we used it splitting all hardwood including elm/hickory so we may have been abusing it a bit.
    WVhunter, papadave and Carbine like this.
  15. papadave
    It does look easy enough.......maybe I could do it.:dex:
  16. Gunn
    Gunn
    Plover, Wi
    Same issues here. I ended up reinforcing the top strap with some angle iron.
  17. WVhunter
    WVhunter
    Mountains of WV
    Yep, that is the only fault I have to mine is the strap on top, mine bent on a piece as well, and it could be a little taller. Not a perfect design, but overall useable and not bad.... JMHO.....;)
  18. DexterDay
    DexterDay Administrator
    Northeast Oh
    For the ash that he would be splitting, I agree. It would probably be fine, but I too would fab some extra support as stated above.
    Ash tends to pop once the wedge hits it.
