Sound Insulation for Basement ....Rockwool?
Discussion in 'The DIY Room' started by Dana B, Nov 12, 2018.
  1. Dana B
    Dana B
    Southern New Hampshire
    We're finishing our basement and once it's finished one of the functions will be a home gym. The boss (wife) says I listen to my music too loud when working out. I was considering using Rockwool that come sin the bags at Lowe's for insulation. Just stick it in the joists. Anyone used it before? Any thoughts on using it for sound insulation?
    Chaz likes this.
  2. Creekin
    Creekin
    Manitoba
    Used it when I built my shop to insulate between an apartment and shop area, worked good! But might be something better?
    Chaz likes this.
  3. Canadian border VT
    I put it between some walls in an apartment building, they stop complaining. There is sound deadening type insulation but the price was Triple.
    Chaz likes this.
  4. lukem
    A double layer of drywall is very good and very cheap sound deadening. Not sure if you are putting it on the ceiling, but if you are, I would double it up.
    Chaz likes this.
  5. Creekin
    Creekin
    Manitoba
    I seem to think there was sound deadening or something with the R value that there were different options, but trying to remember is making my head hurt, if I remember I'll post it up
    Chaz likes this.
  6. Dana B
    Dana B
    I am actually putting it on the ceiling in the basement and was going to do a drop ceiling instead of a drywall ceiling so we'd have access to pipes, refrigerator water hose etc etc
    There were a ton of reviews on Lowes website that said the Rockwool works well for sound insulation but just wanted to see what you guys though about it. Thanks.
    Chaz likes this.
  7. In the Pines
    In the Pines
    You might want to look into a underlayment they use for floors, cork for example does a good job of sound deadening.
    Maybe combine with the rockwool or it might give you an idea to use another item with it at less cost.
    Chaz and Canadian border VT like this.
  8. ironpony
    ironpony
    Mid Ohio
    the most important thing for sound deadening is to have an air gap between materials. Hmmm how to explain.
    if you have floor joists with wood on top (floor) and drywall on bottom it acts like a drum, sound transfers thru the joist, vibration..
    the drop ceiling would create the air gap between materials.
    if you can find (google) sound "proof" wall there will be 2 2x4 walls with the studs staggered so there is no contact between the walls creating that air gap so the vibration, sound, can not pass thru.
  9. Semipro
    Semipro
    SW Virginia
    Rockwool/Roxul is great for this. They even make a version specifically for sound deadening. Our Lowes used to carry it.
    In general low frequencies go through things while higher frequency sounds go around things. Isolate and dampen for the former and air seal for the latter.
  10. wood and coal burner
    Quakertown,PA
    Staggered joists are a good idea, in fact there should be no straight line from the floor above to the ceiling below. Almost like building a floor and then installing a ceiling with its own suspension system. It also needs to be virtually airtight so there is no pass through between floor and ceiling.
    What about a really good pair of blue tooth headphones?
    Chaz likes this.
