Soot Question
Discussion in 'Modern EPA Stoves and Fireplaces' started by trooper, May 23, 2016.
  1. trooper
    trooper
    Arizona: It's a Dry Heat!
    Hi folks,
    I had my first-ever insert installed in 2013, in a cabin that we use part-time year round. The insert's been working great, and I love the results so far.
    Today I had it cleaned for the first time and was a little surprised at the amount of soot that came down. It filled a 5 gallon pail about 3/4 full. There was NO creosote in the pile. I would estimate that I have burned about 1.5-2 cords of wood since initial install. The guy who swept it said I am burning correctly and not to do anything different.
    Is this a large amount of soot? Is the quantity of soot based on things like the type of wood or the stove temps? I always burn dry wood and dry to burn as hot as possible. Perhaps I should just have it cleaned more often?
    Thanks.
  2. papadave
    How tall is the stack? Seems a little heavy on the soot for the amount of wood burned, but if it's not the goo or black shiny stuff, you should be ok. I get maybe a cup or so half way through the season, and I burn 5 full cords every year.
    Possible for you to check it yourself at least once a year?
    During our first winter here, I finally got up to check ours, and found the inside diameter of the 8" pipe had clogged up with a heavy layer of brown fluffy soot to the point the ID was only about 4".
    Previous owners obviously hadn't cleaned, and at the time, I didn't know any better.:headbang:
  3. trooper
    trooper
    Papadave - the stack is about 17'. I have a ladder tall enough that I could check it but would I just take the spark arrestor off and shine a light down the liner?
    The guy who cleaned it cleaned from inside the house (bottoms up) by the way.
  4. papadave
    Yep.
    If you don't have a problem getting up there and/or buying the brush and rods, it's a piece of cake to do.
    Or, do like your guy does. Not sure what he uses, but you could get a Soot Eater, and clean from the bottom. Just make sure the cap gets cleaned too.
    Lots of folks don't like heights (I'm one of those), but I've got an easy to reach setup, so I do it myself. No more than 10 minutes for me.
    If your stove has a removable baffle, remove it before running a brush down from the top to avoid damage and soot buildup on top of the baffle (which will restrict exhaust flow).
  5. Eric VW
    Is the chimney external to the cabin or mostly inside trooper?
    Backwoods Savage and papadave like this.
  6. trooper
    trooper
    Yes, EricVW, it's external to the cabin.
    Eric VW likes this.
  7. Eric VW
    Ok. You usually see issues along the lines of extra creosote because the chimney is exposed, but only soot in the clean out.... I personally wouldn't worry about it- especially if you can monitor it before you fire it up every few times you visit the cabin.
    :thumbs:
  8. Eric VW
    Out of curiosity- what wood(s) do you have in those stacks?
  9. trooper
    trooper
    It's mainly alligator juniper, Arizona white oak, and Emory oak...with a little ponderosa pine :)
  10. papadave
    Reminded me of this....... Eric VW :D
    milleo and Eric VW like this.
  11. Eric VW
    You got it going on there! AWO & EO- I will look them up, I'd like to see some pics.
    Ever had the draft measured? May not tell anything, just wonderin'.....
  12. Eric VW
    Never heard that, and I'm pretty sure I know why:whistle:
    :BrianK:
    J/k Dave.
    papadave likes this.
  13. papadave
    Donovan. Love beads, etc..........
    How 'bout this one........
  14. Eric VW
    I suspect you're not too far apart in age from my Pops......:whistle:
    Which only means I know just about all them older tracks. 'Cos that's all the man listens to.:)
    clemsonfor, milleo and papadave like this.
  15. Eric VW
    Back on track trooper......
    Is this cabin far from your regular residence? High country? Pretty? Pics?
    :thumbs:
    clemsonfor and papadave like this.
  16. trooper
    trooper
    Hey - I remember that! lol
    wildwest, Eric VW and papadave like this.
  17. trooper
    trooper
    I haven't had the draft measured - didn't know that was an option.
    I do know that on some nights in shoulder season, I'll get a burn going when the outdoor temps are in the mid-50s and I noticed that it doesn't draft well at those
    relatively higher outdoor temps.
    Pics coming soon!
  18. trooper
    trooper
    Our cabin is about 120 miles from our home in the Phoenix area. It's in the Tonto NF and about 5600' in elevation.
    Northern AZ has the largest continuous stand of Ponderosa pine in the country. It's pretty neat to be in the desert in the morning and in the forest in the afternoon. Here's a pic looking off the porch at an alligator juniper. It gets its name cuz the bark looks like gator hide. I thought I had a cabin pic handy but will keep looking.
    clemsonfor, milleo, Mag Craft and 4 others like this.
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Your soot volume sounds normal. As long as it's soot and not creosote all should be fine. If that's how clean your burning Mayne switch to cleaning yourself every other year and having the pro every other year....
    The problem with the soot though is it can continue to accumulate and choke the chimney diameter down, this can lead to sluggish starts and dirty glass....
  20. Backwoods Savage
    Very common to have poor draft at those temperatures. A bit harder to get the fire going usually. Sometimes you can heat up the flue a bit before starting a fire and this helps increase the draft. This can be done using newspapers or a torch or even a hair dryer. Also make sure when you are trying to start a fire then that nobody is using the clothes drier or exhaust fans, etc.
    trooper and Eric VW like this.
