Smoke/Co detector?
Discussion in 'The DIY Room' started by Warner, Feb 6, 2018.
  1. Warner
    Warner
    The word has come down from above that they need to be replaced. Any suggestions? The ones we have now are smoke only and don’t have battery back up. As always I’m cheap but don’t think this is an area to be stingy.
    Well Seasoned likes this.
  2. ironpony
    ironpony
    Mid Ohio
    there are a lot of new styles some have all the sensors and are tiny. I was looking at them a while back good luck
  3. Warner
    Warner
    Thanks. I’m more a function over fashion kind of guy.
  4. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I just installed some in a house I’m doing some work at. I put a smoke/co2 detector on each floor. Then I put a smoke detector in each bedroom and in the hall out side the bedrooms. I don’t remember the brand name but the selection at Lowe’s and Home Depot was limited and they were expensive. The smoke detectors had 10 year batteries in them. You can’t change them, you just get new ones after 10 years.
    Mitch Newton likes this.
  5. raybonz
    raybonz Moderator
    Carver, Mass.
    If you prefer function over fashion I suggest you use photoelectric smoke detectors as they are far more responsive than the ionization type.. The difference can be a life saver!
  6. Warner
    Warner
    Thanks guys
    raybonz and Jack Straw like this.
  7. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I saw some pretty slick WiFi ones at Home Depot. They notify your phone no matter where you are and deafen anybody around.
