Wanted! Smaller diesel engine
Discussion in 'FHC Classifieds' started by Sandhillbilly, Dec 4, 2024.
  1. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    At work we have a need for a smaller diesel engine. Something in the range of 35HP minimum up to just shy of 100HP. The boss has determined, and I wholeheartedly agree that the 70ish HP Perkins diesel in my wood chipper would be ideal. Most chippers in the 12” or so range, have engines mounted on a separate frame that slides to adjust the drive belts. The radiator is also mounted to the separate frame and with a clutch mounted on the engine it would be very easy to pick the entire unit off of the chipper chassis and put it into our application.
    So here’s the dilemma, I won’t allow him to cannibalize the engine off my chipper, without a suitable replacement.
    Not much in the way of timber in this area, which means not many used chippers available. And, last but not least, the boss is a Charlie cheap ash, who has a hard time making a decision and then taking action before it’s too late.
    So if anyone knows of a clapped out chipper with a good engine, let me know. Not opposed to something else like a light tower or generator or some such, but a power unit off a chipper seems like the easiest option.
    If you know of something let me know, I’m well aware that a fair road trip would likely be necessary. But anything within 10-12 hours each way wouldn’t necessarily be out of the question
    brenndatomu, HoneyFuzz and wildwest like this.
  2. JimBear
    JimBear
    You might try looking on Big Iron, Machinery Trader or Ritchie Brothers auction site.
    I know the RB has auction sites all across the US, they have one in Lincoln, NE. They get a lot of light towers from the oil patches & other miscellaneous equipment. Very likely they will have some chippers at different locations.
    Sandhillbilly and brenndatomu like this.
  3. JimBear
    JimBear
    eatonpcat likes this.
  4. brenndatomu
    Would that be big enough for your project?
    Those engine are only 15-20HP IIRC...and may have an odd crankshaft, as far as how they attach to whatever they're powering?
    eatonpcat, Sandhillbilly and JimBear like this.
  5. JimBear
    JimBear
    Good point, I was thunking they were a higher rated hp. I suppose it may depend on the size/output of the tower for engine specs but probably not much over 20hp from my brief investigation.
    Sandhillbilly likes this.
  6. Sandhillbilly
    Sandhillbilly
    I watch Bid Iron religiously, and keep a pretty good eye on machinery trader. Kinda forgot about RB, I used to monitor them pretty closely also.
    A light tower would probably work, but a clutch would really be nice. I also have a hard time with the way they advertise the horse power on light towers and generators. Why can’t they just list the HP instead of putting it in KW hp.
    brenndatomu and JimBear like this.
