Small Chainsaw Recommendation?
Discussion in 'Chainsaws and Power Equipment' started by barns1, Sep 14, 2023.
  1. barns1
    barns1
    Cedar Hill, Missouri
    Hi All, What would be your suggestion for a reliable small light weight chainsaw, 16" bar? Thanks
  2. ammoaddict
    ammoaddict
    Granite Falls, NC
    Echo cs352 or 3510.
  3. Locust Post
    I have nothing but good to say about my Echo CS-400 with 16 " bar.
  4. campinspecter
    campinspecter
    Two saws to stay away from Stihl MS 170 hard to start when hot !
    Husqvarna 439 grossly underpowered with a 16" bar !
  5. Sawdust Man
    Sawdust Man
    Of course it depends on what you're cutting.
    For real small stuff (like 8" or less) the cs3510 is a pretty good saw.
    If you want to cut much 10"-14" stuff the cs400 or the new cs4010 are pretty good options, but both those saws get really slow in bigger stuff.
    In my opinion and experience echo is the best option for small lower priced saws.
    I've had a husky 435 and a couple 440's as well as a Stihl ms180, and the echoes have been more reliable hands down.
  6. Chud
    Chud
    NC
    Stihl 201c. The long handle version 35cc
    or 261c 50cc
    I guess it depends on your definition of light.
  7. Jeffrey Svoboda
    Jeffrey Svoboda
    A ported echo 2511.
  8. FarmerJ
    FarmerJ
    Minnesota
    Stihl MS180 has been doing me alright
  9. barns1
    barns1
    Thank you, I'll look into those models.
  10. ammoaddict
    ammoaddict
    Granite Falls, NC
    I've had a 352 for years, great little saw. The 3510 is the new version. I think you can still buy the 352 for now.
  11. Rickyblazin
    Rickyblazin
    Pottstown PA
  12. Eggshooterist
    Eggshooterist
    Erff
    What do you consider light weight? Is there a price range you wany to stay below? I have a few recommendations but they are all over the map on cost.
  13. Eggshooterist
    Eggshooterist
    Erff
    My most used saw. It rips but a 16" would be a bit much. I run a 12" but a 14" would be doable for sure.
  14. Eggshooterist
    Eggshooterist
    Erff
    There is also the echo cs-362. Essentially a rear handle cs-355.
  15. Rickyblazin
    Rickyblazin
    Pottstown PA
  16. Eggshooterist
    Eggshooterist
    Erff
  17. barns1
    barns1
    I was in a water rescue accident while working at our fire district, injured my back, shoulders and neck. I have a Husqvarna 61 and a 450 Rancher that are great for the big stuff, but kill me when I'm cutting smaller limbs. So I guess I'm looking for a saw that I can use around the house and cut up limbs and smaller logs maybe 10 to 12" max. Could be a 14" bar. Price around $300.00.
  18. Eggshooterist
    Eggshooterist
    Erff
    I know all to well about the light weight needs. 4 neck and a lower back surgery has me really limited. My biggest saw is 43cc and 12.8 pounds fully gassed and ready.
    The smaller Echo saws will probably be the best fit for your price. I like Echo as well as any maker. My other recommendations are $500-$800
  19. barns1
    barns1
    Are there any particular Echo's that you like? AmmoAddict suggested the Echo cs352 or 3510.
  20. Locust Post
