Skidding Tongs on a Couple Chunks of Elm
Discussion in 'The Wood Pile' started by tractorman44, Mar 2, 2016.
  1. tractorman44
    tractorman44
    Festus, Missouri
    A couple years ago, my daughter scored a trailer load of elm from a co-worker that had a trimmer cut and block it up. All we had to do was dolly them up the ramps and head out. Some of the cuts were kinda knarly but what the heck. There was at least 12 or 14 of this diameter, then the load was rounded out with smaller stuff on top. With tandem 6,000 lb axles, it was loaded a bit on the heavy side... but not over. Welllll, maybe just a tad over, but the haul was only ten miles or so.
    Here I'm just transporting to the splitter with the little 'bota and the tongs.
    Yes, the little guy has lived a rough life at the hands of a registered tractor abuser. On the second engine and still chugging away it's certainly earned its keep. Of course the first engine was bad when I got it...
    IIRC that's a 14" push block on the old splitter....
    ....and a 16" wedge doing its thing.
    I don't remember exactly what the diameter was, but somewhere around 30"-ish. I think this was three years ago, because last week I got into a pocket of this wood while hauling a little jag into the basement.
    Is that a good daughter or what !!!!
  2. yooperdave
  3. Backwoods Savage
    The daughter or the wood? :whistle: No, not really trying to get you into trouble Dave. If you are like me, you can handle that all by yourself.
  4. Backwoods Savage
    Tractorman, that is one time I can definitely see using the tongs. Never did like them for dragging logs though.
  5. 1964 262 6
    1964 262 6
    williamsburg, ohio
  6. tractorman44
    tractorman44
    Festus, Missouri
    Yeah, me too. We use these tongs and larger ones when we load full length logs with a crawler or a trackhoe. I ain't a fan of skidding logs at all anyway. Well...... I DO have an old home made winch we used to skid logs up the steep creekbanks when there was no other way to retrieve them....but I was a wee lad then and was usually stationed on the lever that made the winch work. I was big enough to pull the lever but not big enough to drag the cable....
    Skidding always seems to imbed the bark with dirt, rock and other debris....and everybody knows what that does to chainsaws or sawblades. I don't know how many times the old man had me peel bark with a double bit axe before we'd even roll a log onto the headblocks.
    On a sidenote, I used that old winch two years ago to pull a buddies 4000 Ford and 12' bush hog out of his lagoon. Sunk above the floorboards and the bushhog was partially sunk in the muck.
  7. Stinny
    "Skidding always seems to imbed the bark with dirt, rock and other debris....and everybody knows what that does to chainsaws or sawblades."... that's one of the biggest reasons I geared up to slide logs out on top of snow. This year tho, kinda tough... no snow.
  8. Spencer
    Spencer
    Indiana
    Huh, I don't have this problem. When I skid logs out, I get them up pretty high so they don't get dirty. And I only skid out 8 ft logs. That's about all I can get on the sawmill anyways.
  9. Stinny
    Yeah, I can't pick mine up and drag. I have to get em on a nose sled and a set of skis so they don't roll. Works well, is enjoyable but time consuming. I really like being down in the woods in the winter so... it works.
  10. Spencer
    Spencer
    Indiana
    Best way to get out of the house in the winter!
  11. NH mountain man
    NH mountain man
    WMNF N.H.
    " Of course the first engine was bad when I got it..........." Sure it was, sure it was. We believe you.o_O:wacky:
  12. tractorman44
    tractorman44
    Festus, Missouri
    I'm sure you are using either a tractor mounted or pull behind log arch or possibly an actual skidder ?? I can see how that would be a great advantage, but in the steep terrain off of the creek banks and down some of the rougher terrain the timber just wasn't accessible on wheels...which is why the old man built the winch. All we had back then was a few tricycle tractors and no way to load except sideways up ramps onto a 20' trailer built out of a Mack truck rearend. BUT we either had to get the logs to the trailer or the trailer to the logs.....
    We do things a bit differently now but not so much for the sawmill as the home place has been long gone and I just recently got my own first mill in operation (50" circular). So until just a year ago, I hadn't sawn anything on a mill since '82. But we still haul logs in lengths up to 26' when possible because so much wood can be transported with so little effort by comparison to blocking onsite. Of course those jobsites seem to have been becoming less frequent lately.
  13. tractorman44
    tractorman44
    Festus, Missouri
    Honest Injun it was !!!! Cross my heart and hope to di....:bug: Welllllll maybe it was.....kinda was anyway..... it would run if the weather was warm or hot but the compression was so low it wouldn't start below freezing. Then another Kubota was given to me after it was burnt in a shed fire, so instead of a rebuild on the original, I just swapped engines. It's quality of life has gone downhill consistently since..... One of these days the straight pipe will go away and the hood and muffler will go back on, but heck, like this it looks like a racing tractor....:cool::cool:
  14. Backwoods Savage
    tractorman44 here is how we do it to keep logs out of the dirt and it works well on steep grades also. I just threw this dray together from scrap for less than $10 (bolts). Pull it behind the atv no matter if we have snow or not. The nice part is you can build one to most any size. Pulling behind the atv I did not want it very wide nor did I expect to haul a real heavy load but we've built some in the past that has hauled some mighty big logs! They work nice. We used to mill a slab off the top and bottom of a log and use those for runners. On this one I just got some old used landscape timbers. I think they were a couple a neighbor was throwing away. I used them.
    Dray loaded.JPG Dray log load 1-29-2016a.JPG Dray-1.JPG Hauling logs 3.JPG Skid logs 2015a.JPG
  15. Spencer
    Spencer
    Indiana
    I fabbed up my own skidding rack for the 3 pt on the back of my tractor. I also have a hydraulic top link. With this combo, I can get one end of the log 2-3 ft off the ground (depending on dia), so only the last foot or so gets dirty on one side (again only with 8 ft logs). Hatchet takes care of that in a couple whacks lol.
    My tractors small enough I can get into some tight spots (its only 24hp) and my property is hilly, but not so steep that I cant find a way to drive to most downed trees. I just try to make sure I fell them in the right direction. I wish I had a pic of the tractor pulling a log but I cant find one right now. I will try to remember this weekend.
  16. Pressguy
    Pressguy
    Central Kansas
    Capital idea!
  17. tractorman44
    tractorman44
    Festus, Missouri
    That certainly is a slick idea, Backwoods Savage... A trailer with no wheels and not nearly as high as a trailer deck too !!! One great thing is with this set up you don't have to worry about being pushed by the load down a hill or even worse being jack knifed while being pushed by the heavy load in slick terrain either. The dray is its own brake.
    That's cool too, Spencer. I've seen others that have put similar ideas to use and they all seem to work quite well. One of the coolest things about FHC is the way it seems to be agreed there is not necessarily only one right way to accomplish a goal as you and Backwoods Savage just illustrated with the pics and/or description of your ways of doing essentially the same thing. Great ideas. See, you CAN teach and old dog new tricks.....
    Spencer and Backwoods Savage like this.
  18. Erik B
    Erik B
    Western Wisconsin
    I have used a choker to drag logs and if there is any slant on the path, the logs roll off to that side. Does the dray eliminate that problem if there is a slight side slant to the path? How does it do when going down hill when you only have a rope connection between the dray and the tractor, in my case it is a garden tractor?
  19. Backwoods Savage
    It is rarely any problem with the dray going sideways off the lanes. Downhill, it all depends on how steep the hill is, how large the load is, if there is snow or ice and how fast the tractor is. I remember many years ago when logging off one woods where there were steep hills. We could not use a tracked vehicle because they were not fast enough going downhill because some of those hills were very steep and quite long. We used a tractor and had lots of fun! A garden tractor will work though if not too hilly. If there is no snow or ice, then the garden tractor should be no problem. A little bit of snow makes it pull pretty darned easy.
    Seems like I remember one guy who rigged a brake on the dray and had someone ride on it to run the brake during the winter months. Hi, yo, Silver!
    NH mountain man likes this.
  20. Erik B
    Erik B
    Western Wisconsin
    I may try to make a dray and give it a tryout. I am working in the woods by myself most of the time so no one available to ride the dray:(
    I will have to look around for some of the details of construction.
