SKF Seals
Discussion in 'Chainsaws and Power Equipment' started by countryhog, Jun 4, 2015.
  1. countryhog
    countryhog
    northwest arkansas
    need to replace seals on my Dayton 2Z463B (Poulan 245SA). I've found some PTO Inner seals on SKF site - 721570 and 711807. they're both
    Description - BLOCK VEE SEAL
    Lip Code - Longlife (Fluoroelastomers) (Lip Code: V)
    Type/Style - BV
    sizes match up pretty well but I don't know squat about materials. the SKF site indicates the fluoroelastomers can withstand fuel and temps up to 490F. any of yall had any experience with these materials?
    DexterDay likes this.
  2. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Jerry, I think Modified Mark can give you the replacements for that saw. I still need to check on the piston for you.
  3. countryhog
    countryhog
    northwest arkansas
    thanks gary.
    btw, do you happen to have a fuel cap you could turn loose of?
    jerry
  4. Guido Salvage
    Guido Salvage
    What saw?
  5. redneckdan
    redneckdan
    Northern Minnesota
    They are Viton or equivilent. Same stuff that is used on the point of a carb float needle. Chemically, they will work good.
    Horkn and dgeesaman like this.
  6. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Dan's right Viton is excellent in fuels and oils with some heat too.
    Take care that the cross-section of the two seals should have the same features. So if the originals have a garter spring, you should ensure the replacements do also and that its' installed in the same direction.
    Horkn likes this.
