Shattered maple is not my favorite
Discussion in 'The Wood Pile' started by billb3, Mar 14, 2017.
  1. billb3
    Hung up shattered maple even less.
    Hung up on three trees.
    Snap, crackle, pop
    We'll see if the wind shakes it out tomorrow. I'm not pinching/bending a bar in it. Not liking being surrounded by briars and not having much of an escape route either. There's a couple other maples on the ground here and this one is hovering over the only good path to it all.
    HDRock, M2theB, RCBS and 10 others like this.
  2. Chvymn99
    Yep don't blame you... Hopefully she'll go ahead and fall now...
  3. NortheastAl
    NortheastAl
    Putnam County NY
    Today's wind should shake it out.
    Backwoods Savage and Horkn like this.
  4. yooperdave
    No hurry.....
  5. bassJAM
    bassJAM
    Cincinnati, OH
    I noticed an ash on my property had fallen like that back in November and got hung up like that. It took until last weekend to finally make it to the ground. There was no way I was going to tackle it otherwise!
  6. MikeInMa
    If you can, put some smaller logs/branches under where you think it will fall. When it does fall, at least it'll be a bit up off the ground.
    Sent from my XT1030 using Tapatalk
  7. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Careful is the only way to be!:salute:and
  8. billb3
    Figures, didn't budge.
    One of the blow downs I really want:
    Hah, the tree it is hung up on is, itself, hung up on another tree.
    A deer came thru this spot today
  9. Screwloose
    Screwloose
    Well for me anyway it seems like if I hope and pray that it Doesn't fall....... It'll fall
  10. NH_Wood
    NH_Wood
    Can you pull it down with a comealong? Cheers!
  11. papadave
    12 gauge
    Even if it doesn't come down, you'll have some fun tryin'.
  12. tfdchief
    tfdchief
    Tuscola, IL
    IMG_4835.JPG worse yet! Hickory stopped at the hinge!! Chief
    HDRock, Horkn, Woodwidow and 8 others like this.
  13. papadave
    What's that thing doing? Just hangin' in the air, or hung up on another tree?
    Power line? :hair:
  14. tfdchief
    tfdchief
    Tuscola, IL
    Hanging in mid air!!! Hickory is tough stuff. Couldn't believe it. It started fall and just stopped when the wedge cut closed up. My son and I stood in amazement for a while and then took the pic. Had to bravely cut the hinge. :hair: Chief
    Horkn, Ralphie Boy, Hellcat and 6 others like this.
  15. billb3
    pole winched it down.
    Now to start slicing.
    Hauling out is getting sketchy as the water level is coming up.
    Dancan, HDRock, tfdchief and 7 others like this.
  16. papadave
  17. basod
    basod
    Mount Cheaha AL
    billb3 if the ground holds out probably a good time to drop the other half, cat face like that may heal years from now after the trunk rots...just extra firewood
    tfdchief, Horkn, billb3 and 3 others like this.
  18. billb3
    One mercy slaying coming up.
    The last one it was leaning on had been leaned on and bent over some time in the past. It should go too.
    tfdchief, Horkn, NortheastAl and 3 others like this.
  19. billb3
    Well found an hour and a half to continue the saga of the swamp maple extraction.
    Pulling it down ended up wedged between 6 trees.
    Except for two I need to cut down the rest are on the ground. I like on the ground, especially maple.
    HDRock, M2theB, Thor and 8 others like this.
  20. tfdchief
    tfdchief
    Tuscola, IL
    Nice looking stuff! Chief
    HDRock, billb3, Thor and 1 other person like this.
