A friend of mine raved about this stuff and he ordered 5 cases, (6 gallons to a case). So what the heck I bought two cases and it is stringy just like snot and appears to be a real good oil, very clear and light colored. Anybody used this stuff? The summer weight is 40 #. Here are some specs: http://www.service-pro.com/documents/WarrenSpecs/WA-Bar&ChainOil.pdf (copy and paste didn't exactly come out the same) SERVICE PRO® BAR AND CHAIN OIL Manufactured with virgin base oils Association of Independent Oil Distributors • www.service-pro.com • P.O. Box 1861 • Montrose, CO 81402 USA Updated: 09/15 SPWNBCOIL DESCRIPTION: SERVICE PRO® Bar and Chain Oil is a premium lubricant designed especially for the lubrication of bar and chains on chain saws, and all types of link chains that require lubrication, including motorcycles and bicycles, as well as farm and industrial uses. SERVICE PRO® Bar and Chain Oil is formulated with highly refined base stocks and an additive package to assure excellent performance as a chain saw bar and chain lubricant. A special tackifier is added to the oil, which promotes good adhesion to moving parts and minimizes oil throw off. These oils are designed to prevent rusting and reduce wear and link breakage thus extending bar and chain life. Penetration into rivet holes and the bat channel is assured. Down-time and cutting interruptions are minimized. • Extends bar, chain and sprocket life • Reduced throw off • Reduces heat build-up • Excellent rust and corrosion protection • Different viscosity weights for various ambient temperatures Winter Summer 20W 40W Gravity, API 30.8 28.9 Density, 0.8708 0.8808 Viscosity @40 Deg. C, cSt 51.29 118.56 @100 Deg. C, cSt 8.21 13.47 Viscosity Index 132 109 Pour Point Deg. F -36 3 PERFORMAN CE BENEFITS: TYPICAL
This Service Pro was not sold in a store, a friend direct ordered from a distributor. Price was decent @ $7/gallon. Essence is the best oil I have come across up till now, IMHO Poulon green jug is good too but this may be better.
