Seepage pit Q (insert poop joke here)
Discussion in 'Everything Else (off topic)' started by cnice_37, Sep 28, 2015.
  1. cnice_37
    cnice_37
    We have a seepage pit rather than typical leaching field in our septic system.
    I have always thought it was a straight shot out of the the tank, about 20' further "downstream." This is what the drawing told me, and I found a small pipe buried close to the surface in that general area which I assumed was a locating doohickey.
    After the grading work I have been doing I stumbled upon a bunch of concrete chunks. Too dark for a pic, but this is a good 15' from where the pit should be, and would be about 45 degrees out from where the tank is. The countours of the concrete lead me to believe it is more than coincidence and something is there. Didn't have time to keep unearthing, it is perhaps 8" under top soil.
    So.... do these things typically have any kind of locating means aside from digging? Would it be likely to be anywhere but "straight" out of the septic tank? Is it possible I have an auxilliary tank not on the drawing? Did I find Hoffa?
    I will take some pics if I can tomorrow.
  2. rottiman
    Chit.................don't know what to tell you.....................:rofl: :lol:
  3. yooperdave
    OK, I've said it before and I'll say it again...
    "A straight flush beats a full house!"
  4. cnice_37
    cnice_37
    I see this will be a productive thread... :picard:
  5. cnice_37
    cnice_37
  6. rottiman
    Where's Gasifier????
    wildwest and Backwoods Savage like this.
  7. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Kinda stinks no one has any answers!:rofl: :lol:
    Gary
  8. wildwest
    Wyoming high plains
    Oh crap!
    On a serious note, I am getting a new system installed, the "leach field" was also broken concrete..... (read extra $$ for removing concrete)
  9. KaptJaq
    KaptJaq
    Long Island, NY
    I have two tanks:
    Some people around here have a tank and a drain field. The drain field has pipes from the tank leading into small concerte "tanks". The small concrete tanks feed porous pipes buried in gravel or rocks or broken concrete that permit the fluids to leech into the ground.
    Try to figure out which components you have found...
    KaptJaq
    Edit:
    PS My guy used a thin steel rod poked through the soil to find the old components. He knew when the house had been built and what the code required back then. Basically said it had to be so many feet from the house and so many feet from the well head. It also had to have a specific slope to help the flow. The further from the house the deeper he probed. It did not matter what the direction was between each part.
    KJ
  10. wildwest
    Wyoming high plains
    How old is your house? I was talking with my septic installer/excavator today and he mentioned he actually has replaced septic systems where the leach field was ancient car buried under the ground. Also, my last leach field at previous house was boulders rather than gravel.
    The new septic system here is replacing large concrete chunks.....
    Backwoods Savage, Stinny and papadave like this.
  11. yooperdave
    Good advice there Kap. Although, you can tell from the images, especially the second, just exactly what the producer of the image was trying to sway your opinion of....
    I've used the "thin steel rod" trick more than once to locate a septic tank....
  12. cnice_37
    cnice_37
    I'm going to have to play scientist and figure this one out. My system, per the drawing, is like KaptJaq first picture. The steel rod I discovered one day out there and matched the location perfectly.
    This other mystery has "backed up" my progress.
  13. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Does everything go out in one pipe? Old houses around here sometimes drained the grey water in a separate pipe. Maybe that's what those concrete blocks are for.
  14. cnice_37
    cnice_37
    Good question but house was built in 1985 and there is no separate grey water line nor tank.
    Jack Straw likes this.
  15. KaptJaq
    KaptJaq
    Long Island, NY
    Do you have two tanks AND a leeching field? I've seen that on occasion on plots that had borderline water absorption ability. They would try to spread the waste water as much as possible.
    Another possibility, was there another house on the site before the current one? Are you finding the remnants of their system?
    KaptJaq
    papadave likes this.
  16. cnice_37
    cnice_37
    To my knowledge no prior buildings here. I also think there is just the septic tank which feeds the seepage pit. That's it... wouldn't be the first time a drawing was wrong or not updated properly when a change was made.
    May be a week before I find out, going to have to build my ark tonight as we are looking at 5" of rain in the next 5 days or something like that.
  17. Backwoods Savage
    Shoot, I know of many who used 50 gallon barrels for their septic tanks. Certainly would not meet code but before the code officers got off their butts many were put in that way. Might be okay for a temporary fix but won't last long.
    papadave and wildwest like this.
  18. wildwest
    Wyoming high plains
    Mine was a rusted out propane tank :bug:
  19. papadave
    Poopage is toxic......doncha know.
    wildwest likes this.
  20. yooperdave
    That's why a propane tank is call an "LP" tank----liquid and poop.
    wildwest and papadave like this.
