Secondary air holes in back of stove??
Discussion in 'Modern EPA Stoves and Fireplaces' started by HDRock, Jan 20, 2015.
  1. HDRock
    I haven't seen or ran many stoves so I don't know, do all the EPA tube stoves have these holes in the back side of the stove ?? , once about half of the Load is burned up I see these secondary holes in the back burning the gases, apparently doing the job they were intended for.
    wildwest likes this.
  2. Highbeam
    Highbeam
    Every non-cat epa stove that I've seen has either tubes with holes or a firebox roof with holes to let in fresh air and combust that unburned fuel.
    Well Seasoned and papadave like this.
  3. HDRock
    I'm talking about secondary air holes that are right in the back of the stove above the fire bricks
    my stove is three secondary tubes plus secondary air holes in the back of the stove.
    I was going to take a picture before I reloaded but I forgot dang it
    I would assume that all the Lopi stoves have these holes in the back but not sure
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm a little confused? Are you talking about the secondary air holes on the inside of the stove or the supply for those tubes/holes from the exterior of the stove?
    HDRock likes this.
  5. HDRock
    On the inside right in the back of the stove
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    I have only owned 2 EPA stoves, the Jotul Oslo and the WS IS. The jotul was like yours, a secondary burn type stove with burn tubes. 3 tubes running E/W with multiple holes in them on both sides of the tubes. The secondary air came from it's own inlet air supply and burned gases high in the firebox. Does your stove operate like this?
  7. HDRock
    Yes but there are also holes right in the back of the stove once the load has burned down one half to three-quarters you can see the gas burner effect coming from these holes in the back of the stove just like you see on the tubes
  8. My IS heats my home
    My IS heats my home
    Albany, NH
    So your saying these holes in the back of your stove are igniting and the burn tubes are not or have and are no longer burning off-gases?
  9. Paul bunion
    Paul bunion
    My Quad has vents in the back that supply boost air for lighting. Or at least they did till they got plugged with ash. That along with the perforated secondary burn tubes long the top. There are two or control rods. One cuts the boost and one controls the primary burn air. Is that what you have?
    HDRock and My IS heats my home like this.
  10. HDRock
    the holes in the back work in combination with the tubes acrossed the top
  11. HDRock
    No I don't have any boost air, no second control ,only one air control
  12. KaptJaq
    KaptJaq
    Long Island, NY
    My VC stove has the four secondary burn tubs on the top and three air vents near the bottom in the front. Those three vents in the front cannot be controlled and provide a fixed amount of air to the firebox at all times. I think the NC-30 has a similar air supply via the "dog house". I was told that air was the minimum air needed so, once the secondaries quit, the coals would continue to burn cleanly and not just smolder.
    KaptJaq
  13. HDRock
    BuckthornBonnie , your stove has the secondary air holes in the back too, right?
    BuckthornBonnie likes this.
  14. MightyWhitey
    MightyWhitey
    Doghouse in the rear of the stove??!!
  15. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    sure does!
    HDRock likes this.
  16. HDRock
    Thanks
    Apparently not all EPA stoves have that feature because no one knows what I'm talking about.
    Does the Liberty have them?
    I will have to get a picture before my next reload
  17. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    concretegrazer and HDRock like this.
  18. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Pics of Avalon Spokane 1750... these do indeed act in the same manner as the secondary tubes. I'm pretty sure the liberty has them as well.
    HDRock likes this.
  19. HDRock
  20. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    No problem, man.
    HDRock likes this.
