Seasoning Time for Black Cherry?
Discussion in 'The Wood Pile' started by Nordic Splitter, Aug 2, 2019.
  1. Nordic Splitter
    Nordic Splitter
    WNY
    All done cutting the log loads and the splitting will commence at 8am tomorrow. Have about 32-35 good size rounds(20-24" in diameter) of Black Cherry I plan on setting aside in one stack after they are split. What kind of seasoning time should I expect from the Black Cherry???? I'm in no rush since all of this is for 2024/25 season.....Just curious though....:)
  2. MikeInMa
  3. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    Thirteen minutes....... then put it under sirloin tip roast.
  4. Horkn
    There's several on this list that are wayyyyyyyy off BTU wise, but most of the drying times are spot on.
    That said if you give cherry 12 months, after split and stacked, it will be dry enough to burn in an EPA stove. 20% or under will be ideal.
    You could check it out with a moisture meter, but you won't need to with 5 years to season. Heck, cut some oak. Even oak will be dry by then.
  5. mike bayerl
    mike bayerl
  6. jrider
    jrider
    Cherry dries out pretty darn quickly
  7. Horkn
    I'd say 9 months in reality. As long as it gets a summer of seasoning it will be ready.
  8. T.Jeff Veal
    Best use right there, or with some chicken, ribs....
  9. buZZsaw BRAD
    A year is good. I dont cut much of it, but did score a couple trees late Winter, early Spring. I CSS right away. Could burn it this Winter if needed.
  10. Backwoods Savage
    I have burned some in less than a year with good results but best to give it a year.
  11. thewoodlands
    thewoodlands
    After our first year of burning, we give it a year like Backwoods Savage said.
  12. billb3
    It will be ready August 4th, 2020 at 9:15 PM.
    Not a minute sooner.
    Plan B:
    Stack it in my back yard and I'll let you know how we made out.
