sealing decorative stove but need for occasional fire.
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by JA600L, Jan 7, 2015.
  1. JA600L
    JA600L
    Lancaster, Pa
    Hi guys, first post in this room. I am running the Woodstock Ideal Steel hybrid for primary heating. I also have a 70's Franklin style stove that is sitting on my upstairs hearth mainly for decoration and the occasional open fire. There is an exhaust damper that I keep closed. The stove pipe goes into a masonry chimney that I keep swept. No insulation. Currently I just jam a handful of roxul insulation up the pipe from the inside of the stove. I leave an item in the stove to remind me the insulation is in there. Should I be doing more to seal this off? Any thoughts?
    wildwest likes this.
  2. fox9988
    fox9988
    NW Arkansas 72717
    The wad of roxul seems fine to me, should stop all the drafts.
  3. My IS heats my home
    My IS heats my home
    Albany, NH
    Is there a need for that stove Jeff? I mean do you need supplemental heat or is the IS doing ok?
  4. wildwest
    Wyoming high plains
    I wonder how much heat you are losing with it. Had a franklin a few decades ago. Heck you could replace it with an electric fireplace for $100 for ambiance.
  5. lukem
    I think you're doing about as best you can do.
    My IS heats my home and wildwest like this.
