Sealing around Class A through block wall?
Discussion in 'Modern EPA Stoves and Fireplaces' started by NVhunter, Dec 11, 2015.
  1. NVhunter
    NVhunter
    Northern Nevada
    What would everyone use around Class A pipe to seal it around the opening in the cinder block wall we put an 8" hole in?
    The pipe is snug but there's a few gaps here and there. What do you suggest I seal it with?
    Contractor said Firestop foam......
    Don't think that's correct...?
  2. papadave
    Refractory cement comes to mind.
  3. bushpilot
    bushpilot
    Eastern Washington
    I don't know. Having said that, this?
    BTW, I don't know.
    basod and Eric VW like this.
  4. Eric VW
    I think a regular mortar would work.... Double walled 6" in an 8" hole?
    Bags, brenndatomu and bushpilot like this.
  5. NVhunter
    NVhunter
    Northern Nevada
    No, it's actually Metal Fab Class A Temp Guard pipe, 6" inner stainless steel flue with 9" exterior diameter, so the hole is actually 9" plus some change... 1.5" clearances to combustibles.
    Mortar is what I'm going to use I think.
    Eric VW likes this.
  6. basod
    basod
    Mount Cheaha AL
    Don't use regular great stuff.
    They sell 3M fireblock foam that is used to seal between penetrations in newer firecode applications - plumbing and wire pulls. I've used it to seal gaps in CO2 protected compartments at work that exceed 350-400F.
    If the gap isn't large high temp silicone would work, or just buy mortar in the caulking tube
    Eric VW likes this.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    How about fire stop caulk, how big is your gap. I believe the 3M firestop caulk is rated to 2000 degrees? If its bigger than caulk can fix I'd suggest hydraulic cement or mortar mix...
    Btw, I'm a contractor with 25 yrs experience.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    High temp rtv might be good too depending on your gap?
    Eric VW likes this.
  9. brenndatomu
    I used mortar, worked great. Been 3 years or so now. Hydraulic cement would be fine too
    basod likes this.
  10. NVhunter
    NVhunter
    Northern Nevada
    Gap is 1/4" in some spots and nothing bigger thab that.
  11. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I'd use the 3M caulk, they have it at HD and Lowes....
    I'm not a fan of foam, it's a pain to remove when the time comes and it can be a sloppy mess.
    Bags and Minnesota Marty like this.
  12. JustWood
    JustWood Guest
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Bags, Locust Post and Minnesota Marty like this.
  14. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    I with Justwood on this one. However, I think bobdog2o02 is also correct and the 3M material will work as wells.
    bobdog2o02 likes this.
  15. Locust Post
    I agree with this one.
  16. Bags
    Bags
    Union, KY
    Fire caulk is the easiest and quickest. Fire foam is a mess and harder to control. Works but more of a quick and dirty application to pass inspections. It is used all the time on my commercial jobs. But it is limited on the sized of the hole or gap which does not affect your small one. Big gaps and holes require fire x drywall and tapped and mudded. Mortar is good too but a bit more time consuming and slightly messy but would look the best if you can see your penetration.
    You have many suggestions above and all will work except the regular foam. I wouldn't use that. So basically it's up to you and what you feel like doing but I'd narrow it down to the fire caulk or mortar. Just me. Good Luck!
    NVhunter likes this.
