Saws Starting and Running in Extreme Cold
Discussion in 'Chainsaws and Power Equipment' started by DBH, Feb 27, 2019.
  1. DBH
    DBH Banned
    Downeast, Maine
    The 3 Stihls have a tough time starting in the low singles F . I tried using Canola oil for lube from a poster here --great suggestion.
    I've tried higher octane, no ethanol, but it is the same hard starts. Am I weak pulling ? :emb:
    Ideas ?
  2. Rope
    Rope
    Alaska
    Are your saw in tip top shape? If your not running your saws often your fuel lines may need to be primed. I run my quite often. In temps down to say -20 it’s full choke for 1-2 pulls the it fires on half choke. As it approaches-50 add a pull per 10*. If the saws are running daily then subtract a pull.
    For bar lube I run Stihl attic for cold temps and whatever is the cheapest bar oil in the summer. Bars and chain are to expensive not to run bar oil. I use Stihl light for the bar and either Stihl or Oregon for chain both are square grind.
    Have you changed spark plugs lately and how’s your filter?
  3. Redfin
    Redfin
    central Pa
    Richen both the L and H a bit for colder weather.
  4. DBH
    DBH Banned
    Downeast, Maine
    New plugs, saws run clearing blowdowns and firewood harvesting mostly in late Fall and Winter ( ~ 8 cords ).
    Local Stihl dealers says I have to pull " hard and fast "; no drop pulls.
    Good ideas.
    Hammy, Woodsnwoods, M2theB and 3 others like this.
  5. Backwoods Savage
    Or simply bring the saw inside overnight.
  6. Screwloose
    Screwloose
    I find that a pre excursion starting at home when it's warm helps. I second the it's to lean comment.
  7. Rope
    Rope
    Alaska
    As a saw builder, Mr. John has good advise. I have been doing a fair amount of cutting lately, so my saw starts quick. I use more of a drop-push down-pull on the rope start. If I can get to the choke and get it to half choke, its a one start, if not then a 2 pull start. Once its warm a one pull start.
  8. Canadian border VT
  9. Redfin
    Redfin
    central Pa
    Mr may be a bit of a stretch.:D
    Op, the colder dense air just requires more fuel both for starting and wide open throttle. Your saws just need some more squirt.
  10. timmyd
    timmyd
    Southwest PA
    Higher octane fuel may not help. It is harder to ignite than lower octane fuel.
  11. Marvin
    Marvin
    Huntingdon, Pa
    Welcome to the club timmyd :handshake:
    Great thread DBH
  12. DBH
    DBH Banned
    Downeast, Maine
    SIR Redfin :salute: ...............................
    "You gotta know what you don't know." Re: higher octane is harder to ignite . Kuddos to Tim.:thumbs:
    SWMBO will not permit saws indoors. Good thot though.
    Drop down start may ( only may ) be safe IF the chain brake is engaged. My CLP instructor said "no" to drop starts. Lots of torque in saw starts that could move the saw towards your errrrrrr.......privates. I like them BTW. So, being the safe one, starts are either held saw between the thighs, or, more common for me at least, foot or leg holding the saw on the ground.
    YMMV
  13. Backwoods Savage
    I was thinking the same thing but couldn't remember for sure which way that went.
    Hammy, Screwloose and Woodsnwoods like this.
  14. Screwloose
    Screwloose
    Okay..... you need to open a thread "how to get saws past wives ?" Heck, I stashed a new push mower behind a couch once.
  15. DBH
    DBH Banned
    Downeast, Maine
    Once huh ? Punished ?
    Hammy and Screwloose like this.
  16. Screwloose
    Screwloose
    Ha, no she never found out. Although a echo with a 36" bar has been under the dining room table for over a week now. I think she is mind numb now.
