Saw chain question
Discussion in 'Chainsaws and Power Equipment' started by Buttercup, Jan 7, 2020.
  1. Buttercup
    Buttercup
    Tennessee
    I’m sure this has been covered but yesterday I was cutting. I went to tighten the tension on my chain and it was tightened all the way. I used it some anyway. My question is what do y’all do about that. I think the chain has some life left but I was wondering what can be done.
    M2theB, Screwloose and dingbat like this.
  2. papadave
    I'd think either the bar is worn, or the chain is stretched...or both.
  3. dingbat
    dingbat
    Western Northern Cackalaky
    Are you certain the bar is the correct mount for your saw?
    Or is it just one that "works"
    I've run in to that on an aftermarket bar I tried on one of my saws. Got to run the tensioner almost all the way out with a new chain. So far I've not hit the end when running that bar, but when the chains stretch a bit, it's close.
    M2theB and Screwloose like this.
  4. lukem
    If you know the bar is correct for the saw, then the chain is probably way stretched out. You may be able to have a link taken out if your local shop spins chains from a reel.
  5. MAF143
    MAF143
    North Central OH
    Make sure your tensioner screw isn't broken, I just had to replace one in a buddy's 661 last summer. It was snapped off and he thought he was out of adjustment but it was just the adjuster tab sitting at the end of the snapped off screw. The parts were cheaper at my local Stihl dealer than anywhere else and he had them in stock.
    How it got snapped off is anybodys' guess...
    RabbleRouser, dingbat and Screwloose like this.
  6. Screwloose
    Screwloose
    Could it be that the chain is just worn out even though it's got tooth life left? I don't like removing any links unless the chain was to long from the start. As the chain stretches/wears the pitch is actually changing and it no longer matches the sprocket.
    Steven Corio, dingbat and MAF143 like this.
  7. Nixon
    Nixon
    West Sunbury,Pa .
    Also, while you are inspecting the items mentioned in the above posts , take a look at your drive sprocket . That tends to be a commonly overlooked item .
  8. The Wood Wolverine
    As mentioned, take it to a dealer and have a drive link removed.
    tamarack and Screwloose like this.
  9. lukem
    You're right. But if this is a 72DL 3/8" pitch chain, you are only changing the overall chain pitch by .005" (.375/72)by removing 1DL. I'm not real concerned about 500 thou on a saw chain.
  10. Screwloose
    Screwloose
    I respectfully disagree as 1/2" should cause great concern!! Haha couldn't resist that, sorry. My thinking is that if the chain was correct in the beginning and you used all of the adjustment range the chain is probaly worn out. Using a 18" bar as in your example the adjustment range in the saw should be more than ample.
    RabbleRouser likes this.
  11. fezdawg12
    fezdawg12
    Elko, Nevada
    I have a ms271 in which the chain adjuster broke the 2nd week I had it. Put new one and never had another problem again. (7 years and 40 cords later).
    Maybe just a bad part in both instances.
    MAF143 likes this.
