Safe hearth construction for an old smoke dragon...
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Beetle-Kill, Oct 3, 2020.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Our office manager has an old stove she is relocating. Standard double door, flat top, 6" flue, free-standing old stove. I do not remember how to calculate the required R-value and clearances required for the old stoves.
    I could use some guidance to help her out. Thanks, JB
    Horkn likes this.
  2. brenndatomu
    What make/model is it?
    There should be an ID/specs tag on it that has all the requirements...if not, they can usually be looked up by model.
    Horkn and Beetle-Kill like this.
  3. Beetle-Kill
    Beetle-Kill
    I just texted her to send me that info. I'll post what she sends me. Thanks.
  4. Beetle-Kill
    Beetle-Kill
    It's tough to read the pictures she sent, but it looks like-
    Kingsman Industries, manitoba, It's got clearance to combustible marks but I can't read them on my phone.
    Kingsman cabin stove- WH- J59933 ? Not sure on that.
    edit- Monster clearance requirements-
    Sides and back- 36", corner 25-1/2", hearth says min. 3/8 asbestos mill board.
    What can she do to get her through the season, then replace it next year?
  5. brenndatomu
    Kinda what I figured...I think you can get a 50% reduction in CTC by putting up an air cooled non combustible heatshield on the wall...usually metal and mounted with non comb. spacers 1" off the wall and 1" up off the floor...obviously you can't use asbestos board for the hearth, but there is a board made for this that can be had at bLowes or HD (the name escapes me right now)
    Chvymn99 and Beetle-Kill like this.
  6. Beetle-Kill
    Beetle-Kill
    I told her we'd build a 4" pedestal base (steel) to set the stove on, and she is ok with wall mounted heat shields. I just hope a 50% reduction would work- she barely has that now.
    Chvymn99 likes this.
  7. Beetle-Kill
    Beetle-Kill
    I do believe she'll be shopping for a new stove this year.
  8. fox9988
    fox9988
    NW Arkansas 72717
    NASD - Wood Stove Installation and Operation.
    CAN RADIATING-TYPE WOOD STOVES EVER BE INSTALLED LESS THAN 36 INCHES FROM COMBUSTIBLES?
    Yes. If a UL-listed stove has a heat shield attached, the clearance can be reduced as specified. Or build a heat shield to be mounted 1 inch off the wall on non-combustible spacers. To reduce the standard clearance to 12 inches, the heat shield should be of 28-gauge sheet metal, mounted off the floor to provide unrestricted circulation of air between shield and wall (see Figure 1).
    comanche79p and Beetle-Kill like this.
